What's the best way to cut and shape plastic? (Material on our oem mudguards)
Old Jun 25, 2006 | 07:55 PM
OneFire's Avatar
Default What's the best way to cut and shape plastic? (Material on our oem mudguards)
I need to cut a section off the two front mud guards so they can fit over my sideskirts. I have a template cut out of the sideskirt shape that i'm going to cut on the plastic mudguard. What's the best way to shape/cut plastic? I want it to look oem, a dremel might work but it'll make the edges jagged, anyway to fix this? any other ideas would be great
Old Jun 25, 2006 | 08:02 PM
Dwight Schrute's Avatar
Default Re: What's the best way to cut and shape plastic? (OneFire)
you can dremel it and smooth it out. i cut plasitc with a dremel and it's not haggard after you smooth it out. maybe cut then use regular sand paper to smooth?
Old Jun 25, 2006 | 08:40 PM
OneFire's Avatar
Default Re: What's the best way to cut and shape plastic? (drewthomas14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">you can dremel it and smooth it out. i cut plasitc with a dremel and it's not haggard after you smooth it out. maybe cut then use regular sand paper to smooth?</TD></TR></TABLE>
What did you use to smooth out the corners? and what grit did you use on plastic?
When you used the dremel, did you use the cutting wheel or did you just sand to shape?
Thanks in advance drew
Old Jun 26, 2006 | 10:37 AM
copperfox's Avatar
maybe a band saw with a thin blade?
Old Jun 26, 2006 | 11:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneFire &raquo;</TD></TR><TR><TD CLASS="quote">What did you use to smooth out the corners? and what grit did you use on plastic?
Thanks in advance drew</TD></TR></TABLE>
there was this attachment that i used that was like a cylinder piece. i'd just use a cutting wheel and cut a little less than what you want and go over it at a lower speed or by hand with sandpaper.
Old Jun 26, 2006 | 11:07 AM
gabebauman's Avatar
A utility knive would be the cleanest cut...but I'm not sure how thick the section you're cutting is.
Old Jun 26, 2006 | 01:50 PM
Morning Call's Avatar
use a dremel. leave about a 1/16th inch more then you need. sand it down with some sand paper, and wetsand it with like 1000grit paper to get a smooth look. you can even put a buffing tip on the end of the dremel and buff out after wetsanding.
this should give you a finish similar if not shinier then the plastic itself
Integra4lyfe069
Apr 21, 2008 05:13 PM
BLUE EH3
Oct 7, 2006 02:14 PM
UNBRE4K4BLE
Honda Civic (2001 - 2005)
May 15, 2006 09:00 AM
rusted_eyes
Honda Motorcycles
Jun 23, 2005 08:54 AM
Jonathan_ED3
May 26, 2005 08:59 AM
