brake dust covers - yes or no?
Searched, but couldn't find anybody else using these (maybe there's a reason?) Anyhoo, some background first - my '01 Lude is a daily driver in the Northeast, so no matter what I do, the brake rotors rust and look like crap. Exhibit A:
I figured, I don't race my car or do autocross, so it's not like I need extra air flowing over the brakes. So I got these things:
Anybody has any kind of an experience with these covers?
With the salt on the Boston roads in the winter and the torrential rains in the summer, keeping the rust off is freakin' impossible. Are there brake rotors that just don't rust, period?
A zinc coated rotor like a Brembo (for example) will not rust. I don't know for sure about other brands, but I have Brembo drilled rotors and they do not rust at all, even on the wear surface of the rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">A zinc coated rotor like a Brembo (for example) will not rust. I don't know for sure about other brands, but I have Brembo drilled rotors and they do not rust at all, even on the wear surface of the rotor.
do you have to order a 'special' zinc coated rotor....because you can tell that to my brembo fronts who i had to use a pry bar to get the wheels off 2 nights ago
</TD></TR></TABLE>do you have to order a 'special' zinc coated rotor....because you can tell that to my brembo fronts who i had to use a pry bar to get the wheels off 2 nights ago
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude »</TD></TR><TR><TD CLASS="quote">
I guess you would really have to double check into the actual rotor you're looking at before you buy it and make sure it's zinc coated. Brembo probably makes non-coated ones also...
</TD></TR></TABLE>I guess you would really have to double check into the actual rotor you're looking at before you buy it and make sure it's zinc coated. Brembo probably makes non-coated ones also...
No offence, but the 2 guys claiming no rust are from Texas.
I have a friend with zinc coated rotors on his Accord and they still rust.
Any more input from people above the snow belt?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">No offence, but the 2 guys claiming no rust are from Texas.
Haha, good point. We only have warped rotors here in TX.
Use a wirebrush to clean the rust off, prime, then paint that area black (or whatever color you prefer)
also, check this stuff out http://www.eastwoodco.com/shop...16026
Autogeek.net
Detailing
Dec 1, 2013 02:54 PM
turboskratch
Southern California
12
Jan 22, 2011 07:48 AM
Jizzmaster Zero
17
Mar 3, 2007 10:04 PM
.. just try to keep your rims clean
