WHO HAS DA INTEGRA BRAKES ON THIER B16A HF CRX?????
Old Jun 25, 2006 | 04:56 PM
EF_ST@TUS's Avatar
Default WHO HAS DA INTEGRA BRAKES ON THIER B16A HF CRX?????
I need to know if you are supposed to have the 90 integra axels because either i got a bad one or my ball joints are bad. Thats the only two things i can think of that would give me a knocking during acceleration right? HELP!!!
Old Jun 25, 2006 | 05:46 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: WHO HAS DA INTEGRA BRAKES ON THIER B16A HF CRX????? (Lost_in_a_world_so_cold)
If you've got a 90-91 usdm pr XSI intermediate, yes you need 90-91 axles with either 91 EX or 90-91 integra hubs.
Old Jun 25, 2006 | 06:06 PM
EF_ST@TUS's Avatar
I have SK-7 half axle and 90 integra axels and whole knuckle and hub assem. from 90 teg.
They are the right length axles on both sides for the EF chassis?
Old Jun 26, 2006 | 06:06 AM
EF_ST@TUS's Avatar
morn bump
Old Jun 26, 2006 | 06:25 AM
Mr_CRX's Avatar
Default Re: (Lost_in_a_world_so_cold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote">I have SK-7 half axle and 90 integra axels and whole knuckle and hub assem. from 90 teg.
They are the right length axles on both sides for the EF chassis?</TD></TR></TABLE>
That should work fine. The SK-7 shaft is from the DA teg, right? As long as you have the intermediate shaft that matches the axles you are using, you should be straight. Also match the transmission axle seals to the axles you are using. ABS or Non-ABS, it doesnt matter.
I'm running the full DA hub assemblies, with a 94+ intermediate shaft and driver's side axle, and a 90-93 ABS DA passenger side axle, because it was what I had laying around. No problems
Old Jun 26, 2006 | 07:36 AM
EF_ST@TUS's Avatar
I get a hard knocking on accel. and i cant figure out what it is. I'm taking it to someone else to deal with
Old Jun 26, 2006 | 08:53 AM
mar778c's Avatar
Community Builder
Check to see if your intermediate shaft is bolted down.
Are your axles aftermarkt? or rebuilt (Autozone, Advance, Pep boys, etc.) Check them
Old Jun 26, 2006 | 10:16 AM
EF_ST@TUS's Avatar
I checked axles and they gave me 2 driver side !! I fixed it its cool now.
andyvaj
May 29, 2013 07:17 AM
got-no-rice
Sep 15, 2011 11:05 AM
SiR_Injected
Aug 13, 2005 05:59 PM
KevronsEG
Dec 10, 2001 12:51 PM
