Removing goo from base sticker.
Old Jun 25, 2006 | 03:42 PM
Adambomb's Avatar
Default Removing goo from base sticker.
Hey, this is a question about removing the sticky goo that's left on the windshield after taking the sticker off.
If anyone's lived on an Air Force base before, then you know what i'm talking about. For those who haven't, when you register your car, they put a decal that siginify's you can go on there. Well, when the time comes to remove it, it leaves a very sticky substance.
I've tried goo gone, but all it did was smear it. Also tried a razor blade since it's glass, and that removed most of it, but the rest smeared also when I tried goo gone again. Anyone have any thoughts?
Old Jun 25, 2006 | 03:48 PM
ERIC!'s Avatar
Default Re: Removing goo from base sticker. (AdamO)
did you let the goo gone sit on there? i used it on mine. worked fine. i wouldnt use goof off i have seen it etch glass before.
Old Jun 25, 2006 | 03:49 PM
SlammedDC2's Avatar
Semper Fidelis
I went to Autozone, or Advanced or one of those and got some bug and tar remover. Took everything off great, if that doesn't work try some simple green.
Old Jun 25, 2006 | 04:01 PM
Adambomb's Avatar
I actually let it sit there for about 5 minutes.
Tried blotting it with a towel, then re-applied some for another 5. That's when the smearing happened.
I'll look into the bug and tar remover though. Need some for my bumper anyways, thanks!
Old Jun 25, 2006 | 11:11 PM
M2S~Juan's Avatar
Just spray it with some water or window cleaner... grab a blade, and scrape! Easy as that.
VTEC_PRODUCTION
Paint and Body
Aug 10, 2007 09:50 PM
SI_you_later
Honda Civic (2006 - 2015)
19
Jun 30, 2007 11:25 AM
Chuck.357
Honda Motorcycles
14
Nov 13, 2006 09:05 AM
hOndafienD 04
May 28, 2004 11:09 PM
MugenPoweredLude
Mar 17, 2003 04:53 AM
