Getting crap out of the tail lights
1990 Integra LS
Somehow while I was replacing my tail light gasket some leaves and crap made their way inside my tail light. I've washed the damn thing out with hot water about 394599591 times now and the stuff seems to be stuck between two layers of plastic, it'll move around but it won't come out. Is there any way to get the **** out without melting the glue and pulling the outer lens? I really don't want to mess with the OEM seal.
Modified by SLH356 at 5:32 PM 6/25/2006
If it's just leaves then I am assuming it's big chunks, right? Maybe you could try to apply a little water pressure and hopefully break up the leaves so it will come out easier. Otherwise you could just be screwed.
