ls overheating need advice
Old Jun 25, 2006 | 03:16 PM
midnightracerx's Avatar
Default ls overheating need advice
hey i recently just changed out a bent rod and numerous other things from a hydro lock from an AEM cold air that didnt have a bypass and went through a big *** puddle. Anyway i fixed the blown head gasket and bent rod and warped head that resulted from that and now i have a serious overheating problem and a hell of a loss in power. I changed out the thermostat and flushed the coolantsystem but nothing has worked i am going to check the motor with a compression testor but that isnt going to help the overheating problem. Any advice would be very helpful seeing this is my daily driver.
Old Jun 25, 2006 | 04:04 PM
Kowalski's Avatar
Default Re: ls overheating need advice (midnightracerx)
How's your radiator?
Old Jun 25, 2006 | 04:31 PM
speedracer209's Avatar
did you change your plugs after all of this? look at all the simple things pistons in ok shape?
Old Jun 26, 2006 | 07:21 PM
pistons ok radiator was fine before hydro lock if anyone is willing to come to winter haven this weekend to help i can offer a paintjob or neuspeed springs which ever you prefer.
Old Jun 26, 2006 | 07:43 PM
Circuit Star-29's Avatar
Default Re: (midnightracerx)
If you had the head milled...it will need it again...if you didn't...shame on you. Your block could also be suspect. The deck can warp.
bksol09
May 21, 2014 01:05 PM
eg6madness
Aug 17, 2006 08:45 PM
shiftinPastU2
Dec 30, 2004 09:30 AM
92silude
Dec 8, 2004 09:33 AM
RenoRacing
Jul 12, 2002 02:06 PM
