downpipe steel braided flex
Old Jun 25, 2006 | 02:35 PM
VspecSiR's Avatar
Default downpipe steel braided flex
when I was having my down pipe fabricated, I also has a steel braided flex pipe welded into place. I recently, had to change an o2 sensor, and whie under my car I noticed that there is a small section of flex pipe that is damaged from scraping speedbumps and what not (I have 3" stainless DP & 3" stainless exhaust) my question is will this create an exhaust leak? what exactly is the flex pipe made up of? how does it work.
Old Jun 25, 2006 | 02:40 PM
playahwitgame's Avatar
Default Re: downpipe steel braided flex (VspecSiR)
well inside of is felxible tubing that has ripples in it so it cam move. then the outside is braided steel to protects it. it obviously allows your dp/exhuast sytem to have some flex so the vibrations dont damage anything. no real way to tell if its gunna leak without being under the car. just tell some1 tou rev your car and stick your hand in the general vicinity of it and if its leaking, you will feel it. becare ful though, it will be hott
Old Jun 25, 2006 | 02:53 PM
turbotime's Avatar
i have a flex bellow on the end of my downpipe, is that different than a flex pipe? Cause mine has no rippled section in it, its SS braid inside and out...
Old Jun 25, 2006 | 03:37 PM
Default Re: (turbotime)
im pretty sure its the same, just maybe a different design by manufacture. they all do the same thing
airwalk07143
Jun 5, 2008 11:58 AM
teddy_dc2
Mar 20, 2007 08:45 PM
jbrick28
Mar 17, 2007 08:00 PM
quikrpm'z
Nov 24, 2001 05:41 PM
