school me....(camshaft)
Old Jun 25, 2006 | 02:32 PM
geces23's Avatar
Default school me....(camshaft)
i am planing on doing a b16 swap into my 93 acura integra...
and i wanted to change the camshaft...
what camshaft should i go with...
and is that a smart choice???
Old Jun 25, 2006 | 02:35 PM
BlueIntegraBoy's Avatar
Default Re: school me....(camshaft) (geces23)
It all depends on your goal and how much moolah you have. There are camshafts for many different applications. In addition to camshaft shopping, you should consider higher CP pistons and valvetrain to go along with it.
Old Jun 25, 2006 | 02:57 PM
akstunt600's Avatar
get some stage 3 cams, crower,web,toda,ect.... for the most part there all good, and a spoon high compression head gasket. u should be able to harness some power with that.
stock valve train will work but i would reccomend the minimum of springs, reatainers, keeper/locks
Old Jun 25, 2006 | 03:04 PM
geces23's Avatar
thankz from the both of you...
still kinda new to the scene but i know what i want...
am i heading the right direction for my future plans from my motor???
Old Jun 25, 2006 | 03:31 PM
lVlemphizStylez's Avatar
Default Re: (geces23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geces23 &raquo;</TD></TR><TR><TD CLASS="quote">thankz from the both of you...
am i heading the right direction for my future plans from my motor???</TD></TR></TABLE>
why are you swapping in a b16??? id say thats a step in the wrong direction..personally
Old Jun 25, 2006 | 03:39 PM
akstunt600's Avatar
for goin all motor its alittle odd of a choice.
i had figured you had done SOME research and knew what you where getting into by chosing the torque-less b16.
a good turbo setup would be aftermarket pistons and stock rods, with a nice t3/t4, inj.'s, and some sort of EMS. you could easily make 300hp. off the b16, with quite a bit of torque.
however if you are still set on goin allmotor i would deffinatly choose to refresh your bottom end, new bearings,rings, gaskets and seals. then go buy a b16/or gsr vtec head and build a nice ls/vtec setup.
Old Jun 25, 2006 | 03:50 PM
Default Re: (akstunt600)
a turbo b16 given same specs will produce far less torque than ANY turbo b18...
Old Jun 25, 2006 | 05:55 PM
akstunt600's Avatar
^no ****, i just said it would be torquey
Old Jun 26, 2006 | 01:02 AM
Ricer no 7's Avatar
Yah why are you motor swaping a b16? You have an ls integra right? There no need to swap a motor when you could make that power with your motor relatively more cheap with less money than doing a swap.
If your gonna do the trouble of a swap at least do a b20, gsr, or k20 hehe thas prolly out of your budget.
Anyways give more details you can't expect to learn without the research look around and figure out what you want and how much you are going to spend.
Old Jun 26, 2006 | 01:05 AM
Ricer no 7's Avatar
you should go with a lsvtec though. Then dicide what you want a drag car, circuit car, auto x (prolly not though you don't really need to mod for that). Figure out what you want then we can point at a cam
Old Jun 26, 2006 | 01:38 PM
geces23's Avatar
aight this what i was thinking about...
i wanted a b16 and maybe tune out the head on it...
and then some...
im not really gonna race this ****...
just wanted my car fast enough not to be slow...
i wanted something dat would make a suprise
and a little project...
and see what i can get out of that b16...
Old Jun 26, 2006 | 01:41 PM
geces23's Avatar
really feeln a jdm feel...
but i have a friend...
whos kind schooling me one this ****...
so sound like the b16 is my kinda feel...
i was thinking of an lsvtec...
but i wanted something different...
Old Jun 26, 2006 | 01:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geces23 &raquo;</TD></TR><TR><TD CLASS="quote">aight this what i was thinking about...
and then some...
just wanted my car fast enough not to be slow...i wanted something dat would make a suprise
and see what i can get out of that b16...</TD></TR></TABLE>
yea those dont mix well in an integra...so youre already a step behind...the b16 will be slow...and what do you mean tune out the head?
Old Jun 26, 2006 | 01:45 PM
-Championship-'s Avatar
76.169.175.137
from a 1834cc to a 1598cc displacement how sad...yo man just get a b16 vtec head go ls/vtec, and then youll know the difference between your friends b16....
Old Jun 26, 2006 | 01:47 PM
geces23's Avatar
ok so is that really a bad choice???
am i going the opposite way???
yes you are going in reverse...the b16 lacks the torque to move your car to anything remotely quick
Old Jun 26, 2006 | 01:49 PM
geces23's Avatar
dam...i guess i did some bad research then huh...
Old Jun 26, 2006 | 01:51 PM
76.169.175.137
Default Re: (lVlemphizStylez)
b16 are good for..................damn i forgot
go ls/vtec...more torque than the crappy 111 lbs of torque and even less at the wheels...just get this....ls/vtecs are faster than most stock gsr's
and b16's are like the scion xb supercharged,a dn trust me there slow
Old Jun 26, 2006 | 01:56 PM
geces23's Avatar
by tuning the head...
i meant by change the camshaft...
and getting them polished...
maybe even chaging some valves
and springs
Old Jun 30, 2006 | 02:16 AM
Ricer no 7's Avatar
what is your budget? And are you doing the work yourself?
Old Jun 30, 2006 | 12:44 PM
geces23's Avatar
no but my buget right now is about 4gs
watisjdm
Jul 11, 2008 12:47 PM
pnltnc
Honda S2000
Feb 10, 2007 06:07 PM
allmotorsecret
Mar 23, 2006 10:50 PM
Type RS
Apr 4, 2004 10:15 AM
R@mon
14
Oct 14, 2003 03:08 PM
