plug wire question
im not getting spark in my car, and have checked everythign and am running out of ideas. i noticed my spark plug wires arent all the same length, and one seems to have a n extra bit of rubber on it, it could be normal but i wanted to check with you guys. they are y8 plug wires i believe (bought them a long time ago).
#1 has an extra bit of rubber on the end, and #1,2,3 are all the same length. #4 however is a bit longer, hard to tell with the pic, but believe me it is. is this normal? im only bringing this up becuase it seemed as if one of the plugs, the one with the extra rubber, didnt go all the way down when i push it in.
also are y8 and z6 plugs interchangable?
don't mess around,
get new plugs.
those look like aftermarket anyways,
you're only stepping down if you don't get oem honda for ignition.. unless ur running like 900whp or some ****
go to honda and get the right plugs for your car,
try that.
if it's just a stock motor or something though, you could probably get away with autoparts brand plugs.. as the honda ones are pretty expensivo
theres also hondaautomotiveparts.com
get new plugs.
try that.
thats the thing i bought these new from schucks, its just a stock z6, ive never had a problem with schucks plugs for a daily driver, but i dont get why they are diff like that.
smokerz212
Nov 20, 2006 03:32 PM
