Rear shock forks to narrow...
I bought a used set of KYB AGX shocks for my 95' GSR.I was told by a respectable seller on here that he knew they were for a EG/DC2.
I just lined them up with the LCAs and there to narrow.Anybody have an idea what there for?EK possibly?
im 100% sure, i work at IMPOperformance we are honda specialists i do alot of suspension work for customers. kyb's and stock replacement gabriel shocks are often bent inward and must be bent into shape to fit.
dont bent them if its more then 1/8th of an inch diffrence. If they are any more then that, you were sent the wrong shocks, or the guy is full of ****. you cant bend it out it its 1/8"+
i figured he's exagerating quite a bit, most of the time they r bent inwards slightly so that they get a tight fit.
of coarse they shouldn't be bent beyond reason, if it dosent look like a match then theyre most likely not for a honda.
I looked up the part # and there for 96-00 civics.I also measured it and there exactly 1/4 inch more narrow than stock.
Will a EK LCA bushing fit in the DC LCA?Either that or shave 1/4 inch off of the bushing which I really dont want to do.
akstunt600 I sent you IM
Thanks
Thanks
