ok ckp sensor on a multi point conversion somthing simple i hope
ok 91 ef civic dx sith si ecu si multi point and si distributor all straight off a working car it worked great accept the ckp sensor kept poping on ever so often si i checked all the wires and resoldered everything its nice and tight and it ran great came out to start it and now its constantly on what do you think the problem is
Thanks
Thanks
i am having the same problem, have check the wiring, properly solded, check continuety,
I opened the disstributor last night and there was rust in side it,
the distributor is a OBD1 non-vtec which i am using on a b16a converted to obd1,
89 CRX SI
27
Jan 20, 2003 04:12 PM
