Crx starting problem
Old Jun 24, 2006 | 05:50 PM
Walshie's Avatar
Default Crx starting problem
I got a 90 hf allll stock and its not starting right, gets alot of this waanininininininini and it will like almost start then bog out and then die. 202000 help?
Old Jun 24, 2006 | 05:53 PM
2poor2tune's Avatar
i would start by messing with the distributor. losen it up and move it back and fourth uthen start it at different points see if it stays running ever. sorry if that dont help.
Old Jun 24, 2006 | 06:02 PM
Walshie's Avatar
thanks ill give that a try and if that dont work?
Old Jun 25, 2006 | 05:23 PM
CLE's Avatar
CLE
Check compression, check for spark, check for fuel. Those are the 3 things you need to start an engine.
wentcrazycrx
Aug 1, 2007 11:09 AM
bboy_mikey
May 20, 2007 05:56 PM
rob42386
Sep 30, 2005 12:42 PM
contimheokho
16
Oct 26, 2004 07:34 PM
BLuDoHcReX
11
Feb 5, 2003 05:32 PM
