Hondabond, Ultra Flange II??
Old Jun 24, 2006 | 03:44 PM
white90crxhf's Avatar
Default Hondabond, Ultra Flange II??
Went to the honda store today, asked for some honda bond, i was told there are 3 kinds. i told him i was sealing my transmission, so he gave me the red bottle, the part # is not the same as the manual(which i didnt bring with me like an idiot).
it says it's high temp 625degrees. "exceptional oil resistance" low odor/non-corrosive. outstanding coolant resisitance. safe for 02 sensors.
part number is 08718-0009, is this a suitable alternative? or do i need to return it?
Old Jun 24, 2006 | 08:05 PM
rioninja's Avatar
Default Re: Hondabond, Ultra Flange II?? (white90crxhf)
Im not 100% sure without checking, but chances are that what you got is for oil pan gaskets. It will work on your tranny fine however.
If you want to save a few bucks, Permatex (the makers of that AWFUL silicon gasket maker) has a fairly new rubber sealant out. Its basically imitation hondabond. Has the same consistency and oil resistance as the real stuff. Lot cheaper too.
http://www.midwayautosupply.co...20010 Some autozones carry it around here.
Old Jun 25, 2006 | 09:21 AM
that stuff is only good to 400degrees? how hot is the transmission oil getting?
Old Jun 25, 2006 | 01:13 PM
Targa250R's Avatar
be professional
Default Re: (white90crxhf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90crxhf &raquo;</TD></TR><TR><TD CLASS="quote">that stuff is only good to 400degrees? how hot is the transmission oil getting?</TD></TR></TABLE>
The transmission oil doesn't get anywhere near that, and neither does engine oil. If you're running 400*F oil temps, you're going to have more serious problems.
FearTheH
13
May 21, 2009 12:12 PM
deechiguy
Acura TL, RL & ZDX
Jan 28, 2005 10:15 AM
Boostless97Lude
Jan 31, 2003 08:33 AM
d0nkeyxPunch
May 10, 2002 04:01 AM
