How wide of a tire can I fit on my stock steelies?
Old Jun 24, 2006 | 03:15 PM
Jizzmaster Zero's Avatar
(banned)
Default How wide of a tire can I fit on my stock steelies?
92 sedan, right now I have 175/70/R13 crap tires on there and they squeal when I take a corner not even going that fast. I was hoping that I could fit some wider tires on there to help with launches. Can I fit 185? 195? How big can I go? All I've ever had on the stock wheels are 175's.
Old Jun 24, 2006 | 03:19 PM
JDM Vision's Avatar
Default Re: How wide of a tire can I fit on my stock steelies? (Jizzmaster Zero)
just get rims
Old Jun 24, 2006 | 03:35 PM
(banned)
Default Re: How wide of a tire can I fit on my stock steelies? (JDM Vision)
No thanks. I'd like to keep my rusty steelies to maintain my sleeper status.
Old Jun 24, 2006 | 03:37 PM
komat's Avatar
get 15" steelies then
Old Jun 24, 2006 | 03:39 PM
(banned)
Default Re: How wide of a tire can I fit on my stock steelies? (komat)
If anybody wants to answer my original question and not be an asshat like the 2 guys above me, feel free to input.
Old Jun 24, 2006 | 03:47 PM
Slopoke's Avatar
Sumitomo HTR 200 comes in a 205/60/13.
They are a little wide, but they will fit(I have personally seen it).
*edit- check out Tirerack.com.
Old Jun 24, 2006 | 03:48 PM
komat's Avatar
Default Re: How wide of a tire can I fit on my stock steelies? (Slopoke)
205/60
will drop his car down like 2in
Old Jun 24, 2006 | 03:56 PM
Voyage34's Avatar
wider wont help much but getting better tires will. the issue you run into is that very few performance tires, the ones that wont squeal when you take a corner slow, and will let you take corners fast, come in a 13". if you _simply_must_ have steelies, at least get 14" because then you have a few options such as the yokohama es100, and falken azenis come in a *few* 14" sizes.
but if you are dead set on running the mostly **** tires available in 13 but think getting wider will help, you may be able to fit up to about 185 section width on there.
Old Jun 24, 2006 | 04:00 PM
Voyage34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">205/60
will drop his car down like 2in</TD></TR></TABLE>
205/60/13 has virtually the same outer diameter as 175/70/13. the 205/60 is 1/10" larger. no it wont drop his car. but that tire size isnt approved for 5" wide rims, only 5.5"-7.5"
Old Jun 24, 2006 | 04:19 PM
(banned)
Default Re: How wide of a tire can I fit on my stock steelies? (Voyage34)
So bottom line is, I can fit 205 wide tires on my rims?
Old Jun 24, 2006 | 04:30 PM
plz turn off trial user's Avatar
ya, id say keep 13" , help his unsprung weight out a lil, id say if it fits expletive it put em on and go drivng
Old Jun 24, 2006 | 04:39 PM
Voyage34's Avatar
you cant fit 205/60/13 on 13x5 rims. pretty much the only tire in that size needs a 13x5.5
*edit* there are some R-compound tires in a 13" size, most needing a wider rim though, and not recommended for street use because of warmup time needs and little breakaway warning.
Old Jun 24, 2006 | 05:50 PM
(banned)
So then I can fit a 195 tire on these rusty pieces?
Old Jun 24, 2006 | 05:54 PM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">get 15" steelies then</TD></TR></TABLE>
Word, then get good falkens.
Old Jun 24, 2006 | 06:31 PM
(banned)
Default Re: How wide of a tire can I fit on my stock steelies? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Word, then get good falkens.</TD></TR></TABLE>
Old Jun 24, 2006 | 06:42 PM
DohcSide's Avatar
your not gonna get any help with that additude
Old Jun 24, 2006 | 06:49 PM
(banned)
Default Re: How wide of a tire can I fit on my stock steelies? (DohcSide)
I don't care for "help" from people that don't give any.
Old Jun 24, 2006 | 06:53 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">you cant fit 205/60/13 on 13x5 rims. pretty much the only tire in that size needs a 13x5.5
*edit* there are some R-compound tires in a 13" size, most needing a wider rim though, and not recommended for street use because of warmup time needs and little breakaway warning.</TD></TR></TABLE>
What you can fit and what is "recommended" is two completely different things.
You CAN put 205's on your 5" wide steelies. I HAVE SEEN IT.
Old Jun 24, 2006 | 07:07 PM
is it a good idea? no but if he wants to do it then let him go for it shiiiiiyte
Old Jun 24, 2006 | 07:15 PM
slkleltlclh's Avatar
just get 195, and if those dont work, then get 185 =] trail and error
Old Jun 24, 2006 | 07:20 PM
(banned)
Default Re: (slkleltlclh)
Sounds like I'm gonna get some 195s
Old Jun 24, 2006 | 07:29 PM
CBEengineering's Avatar
Default Re: (Jizzmaster Zero)
you my friend are a dumbass the first couple of guys were trying to save you from wasting your money...ive got some rusty steelies that are 14s and you can put a decent tire on them for not alot of money....too bad your sleeper image wont help if your cars not fast
Old Jun 24, 2006 | 07:42 PM
(banned)
Default Re: (CBEengineering)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering &raquo;</TD></TR><TR><TD CLASS="quote">you my friend are a dumbass the first couple of guys were trying to save you from wasting your money...ive got some rusty steelies that are 14s and you can put a decent tire on them for not alot of money....too bad your sleeper image wont help if your cars not fast</TD></TR></TABLE>
Such a closed mind... tisk tisk.
13.8 on shitty used tires from the local shop good enough for you?
Old Jun 24, 2006 | 07:47 PM
ooooh e-thug 13.8 is smoking...ha
Old Jun 24, 2006 | 07:52 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzmaster Zero &raquo;</TD></TR><TR><TD CLASS="quote">
13.8 on shitty used tires from the local shop good enough for you?</TD></TR></TABLE>
Pwned
