Broken axle stuck in tranny (pics attached)
Old Jun 24, 2006 | 12:49 PM
XES's Avatar
XES
Default Broken axle stuck in tranny (pics attached)
I broke my passenger side axle at the track yesterday. It is an aftermarket axle (therefore is very very difficult to drill). I have a Quaife lsd so my main attempts have been trying to hammer it out from the drivers side. I think the problem is the snap ring on the inside preventing it from coming out.
Please offer any advice you can.
Old Jun 24, 2006 | 01:11 PM
charlee's Avatar
the only thing u could do is hammer with a longer rod and with a sledge hammer or sumthing.thats the only thing worth doing that i can think of
Old Jun 24, 2006 | 03:36 PM
wilham320's Avatar
Default Re: Broken axle stuck in tranny (XES)
yep, mine broke the same way... i beat on it for a day or two, then i gave up and put a new tranny in.
Old Jun 24, 2006 | 05:52 PM
non-VTEC's Avatar
keep trying to hammer the thing with a punch from the other side......try to use long 1/2" socket extensions from the drivers side wheel well and swing at that.
im willing to bet the splines are twisted/bent allong with the snap ring that is holding it in which will make it hard to get out.
or your gonna have to pull that tranny apart and change that diff.....
Old Jun 24, 2006 | 06:25 PM
XES's Avatar
XES
Default Re: Broken axle stuck in tranny (non-VTEC)
I sprayed wd40 on both sides, and beat the living **** out a rod that I slid into the hole. It will not move at all. If i drill a hole in it could that be any help? How can the c clip be dislodged?
Old Jun 24, 2006 | 06:29 PM
charlee's Avatar
well if ur gonna drill a hole drill a big enough hole to weaken the center of the axle. at the same time weakening the center of the ring as well. then ur gonna try and brake what ever is left os the axle after being driled with a crowbar or sumting.
Old Jun 24, 2006 | 06:30 PM
Natural Aspirations's Avatar
Take it apart, or you risk breaking your tranny case. Its not ment to take that type of impact.
Old Jun 24, 2006 | 06:49 PM
non-VTEC's Avatar
try a air hammer if you can find a bit thin and long enough to fit through
Old Jun 24, 2006 | 09:03 PM
Aquafina's Avatar
If you can disassemble the Quaife like you can an OEM diff, then pull the diff out and take it apart.
I broke an axle off in my OEM D16Y7 diff and had to do that.
Old Jun 25, 2006 | 10:02 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES &raquo;</TD></TR><TR><TD CLASS="quote">I broke my passenger side axle at the track yesterday. It is an aftermarket axle (therefore is very very difficult to drill). I have a Quaife lsd so my main attempts have been trying to hammer it out from the drivers side. </TD></TR></TABLE>
Are you sure it's the axle your hitting from the drivers side? And not part of the lsd? Checking out my obx there isn't anyway to get through.
Old Jun 25, 2006 | 12:23 PM
XES's Avatar
XES
Default Re: Broken axle stuck in tranny (Chiovnidca)
I tried drilling it (which failed). So I ended up pulling the tranny and diff out of the car....but i still can't get it out. Should I use a press and press an object through the small hole (shown in red)?
Old Jun 25, 2006 | 01:35 PM
Chiovnidca's Avatar
Since you have it out of the car, wouldn't be easier to just take it apart?
Old Jun 25, 2006 | 04:28 PM
0618turbocivic's Avatar
just take the trans apart that way you can see if anything is broken off inside doesnt hurt and it should make it easier goodluck
Old Jun 25, 2006 | 09:50 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Broken axle stuck in tranny (0618turbocivic)
damn seen this happen to a friend of mine at the track...we drilled, tapped it screwed a long bolt in and pulled it out had to push with a bar off the bolt some, but it worked good luck 2 hours from home we tried anything and it work
Old Jun 25, 2006 | 09:58 PM
hybrid1990crx's Avatar
Default Re: Broken axle stuck in tranny (DBL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBL &raquo;</TD></TR><TR><TD CLASS="quote">damn seen this happen to a friend of mine at the track...we drilled, tapped it screwed a long bolt in and pulled it out had to push with a bar off the bolt some, but it worked good luck 2 hours from home we tried anything and it work</TD></TR></TABLE>
thats what i was thinking.
you can drill it out, tap some threads into it, and then put a bolt into, then get a puller, like for truck wheel bearings, and try to pull it out like that. Or maybe take it to a machine shop that has a 10,000 pound press and have to try to push it out.
Old Jun 26, 2006 | 07:52 AM
Chris22215's Avatar
Default Re: Broken axle stuck in tranny (hybrid1990crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx &raquo;</TD></TR><TR><TD CLASS="quote">
machine shop that has a 10,000 pound press and have to try to push it out.</TD></TR></TABLE>
probably will end up being the safest way out.
Old Jun 26, 2006 | 01:02 PM
XES's Avatar
XES
Default Re: Broken axle stuck in tranny (Chris22215)
I ended up shipping it out to Quaife today....since pressing it with the small press I have also failed.
Old Jun 28, 2006 | 08:12 AM
slow poke's Avatar
I was just going to say... Quaif will get it out for you!
Lifetime Warranty Baby
fin781
Aug 15, 2012 06:22 PM
Parker69
Oct 19, 2006 08:28 AM
XES
Jun 26, 2006 05:58 PM
TurBoTeG
Aug 13, 2005 02:33 PM
B18EG6
Jun 24, 2004 04:33 PM
