90 dx mpfi swap out of 94 civic. do i need a resistor box
Old Jun 24, 2006 | 11:13 AM
memorybox's Avatar
Default 90 dx mpfi swap out of 94 civic. do i need a resistor box
Ok i found a 94 civic sedan and i got the distributor, intake manifold, injectors, fuel rail, head, and ecu, and wiring harness. All of the mpfi how-tos i found said i needed a resistor box if coming from a si. But since i got the ecu out of the 94 civic will i be able to do the swap without the injector box? thanks
-daniel
Old Jun 24, 2006 | 11:18 AM
SD_Lurker's Avatar
HT White Ops
Default Re: 90 dx mpfi swap out of 94 civic. do i need a resistor box (memorybox)
A 94 engine is obd1 so if you are planning running obd1 then you dont need the box!
Old Jun 24, 2006 | 11:22 AM
memorybox's Avatar
Default Re: 90 dx mpfi swap out of 94 civic. do i need a resistor box (nicks_jdmstyle_ef9)
so ill have to do the obd1 swap then?
Old Jun 24, 2006 | 11:32 AM
Rywire's Avatar
you dont with obd1 inj. You have to give the inj 12v+ rather than a inline resistor
Old Jun 24, 2006 | 11:33 AM
memorybox's Avatar
Default Re: 90 dx mpfi swap out of 94 civic. do i need a resistor box (droppedcrxsi)
ok but im using the ecu out of the 94. if i use that will i not have go obd1? or can i use my stock ecu and just run 12v
Old Jun 24, 2006 | 11:41 AM
Rywire's Avatar
injector obd has nothing to do with the ecu... What inj are you using?
Old Jun 24, 2006 | 11:44 AM
memorybox's Avatar
read my post lol. its all out of a 94 civic. i had all the parts from the howto to do the swap except the resistor box. what im saying is if i install the 94 ecu for the mpfi swap will i need to do the obd1 swap? or can i keep my stock dpfi ecu and just not need the resitor box
or: do i need to get a 90 si ecu and 90 si resistor box
Old Jun 24, 2006 | 11:49 AM
SVOboy's Avatar
OBD1 injectors do not need a resistor box.
And obd1 ecu will need an obd1 swap, and I dpfi ecu won't work with any mpfi swap.
You can get a 90 ecu and use no resistor box if you're still using the 94 injectors.
I have an obd1 dizzy for sale if you wanna do the obd1 swap.
Old Jun 24, 2006 | 12:32 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memorybox &raquo;</TD></TR><TR><TD CLASS="quote">read my post lol. </TD></TR></TABLE>
Read what I said... "lol"
repingjdm
10
Sep 28, 2010 04:37 AM
thundernutz
Sep 8, 2009 10:27 PM
Bullett
16
Apr 29, 2004 07:08 PM
turbohf
Nov 13, 2003 06:58 AM
SteveeeO
Mar 3, 2003 07:38 PM
