HAve JDM 5Lug Conversion, what wheel Bearing ?
My buddy has a JDM ITR 5 Lug Conversion for his EG. He has no idea what year the 5 lug is from, but it is NOT USDM.
He bought brake rotors, pads for a 2000 ITR , unsure if they will fit or not as there is conflicting info on HT.
He also took the hub bearings out to get the suspension powdercoated, he wants to replace the Hub Bearings, but is unsure what part to buy.
My next question is, IF he has the 36mm Spline 5 lug, what axle do you use as the USDM axles are 32mm.
Any help is appreciated, i search for about an hour an found TONS of mixed results.
CRV wheel bearing will work.
to make the 32mm axle work you need a 36mm outer hub also CRV.
2000 itr pads and rotors will work. they are the same for 32 and 36.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD »</TD></TR><TR><TD CLASS="quote">So he needs a CRV wheel bearing, an swap the CRV 36mm OUTER AXLE onto his stock GSR axle.</TD></TR></TABLE>
correct. it might be cheaper to get reman crv axles, then to buy just the outer cv joints from honda.
this is for 97-01 crv.
94allmotor
Mar 16, 2011 12:47 PM
