climate control, vents not working
I did a search and foudn this thread
https://honda-tech.com/zerothread?id=1160242
This user also had no luck with any replies.
my temp works, as well as fan speed but my vent selection does not. The selection light and everything changes just not the vents, no matter what its always on dash and feet.
im going to a wrecker tommorow to get some stuff with a friend for his car, woudl it be in my best interest to grab a control, or can i fix it?
alrite ill go look thru my crx servic e manual
edit: my 1991 civic crx service only had the civic heater control in it which uses the cables where as my crx only uses the cables for the temp and the rest is electric. guess ill have to just go and look.
Modified by c0nspire at 6:56 PM 6/24/2006
its fixed, there was a plug by my throttle pedal. I ran a steel braided line in from the engine bay right next to it for my oil pressure gauge, must have been pushing on the tab causing the plug to fall out.
Thanks :D
Thanks :D
Silver93t
Jan 19, 2012 08:57 AM
STHPERFORMANCE
Feb 14, 2003 12:25 PM
