need new bushings...
Old Jun 23, 2006 | 06:55 PM
efyou's Avatar
Default need new bushings...
ok well im curious about a few things regarding this subject.
1. will OEM all around cost about the same as the ES master kit? well the master kit doesnt cover EVERYthing, but i mean including what it doesnt cover too.
2. do i only need a press for the LCA or for every single bushing?
and 3. how long would i expect to work on this if doing it all at the same time?
its my DD. mileage>200k = needs pretty much new suspension lol.
Old Jun 23, 2006 | 07:34 PM
JJ's civic's Avatar
Default Re: need new bushings... (efyou)
bump for time frame i need to do a new bushing install and stoxk motor swap out and in.?
Old Jun 23, 2006 | 08:19 PM
efyou's Avatar
Default Re: need new bushings... (joeny12985)
bump
Old Jun 23, 2006 | 08:38 PM
EF_ST@TUS's Avatar
I would not go with poly, I have heard bad things and tyson has made me a believer of stock bushings, after driving his car, I felt like mine was a peice of crap. Go stock poly limits the radial movement of your joints. the OEM bushings are the most reliable, quiet, and long lasting. My 2 cents...
Old Jun 24, 2006 | 07:47 AM
efyou's Avatar
Default Re: (Lost_in_a_world_so_cold)
thx lost, anyone else?
Old Jun 24, 2006 | 08:58 AM
EG_H2B's Avatar
poly all the way. factory bushings do not alllow the suspension to pivot freely.
Old Jun 24, 2006 | 08:30 PM
eda6's Avatar
Default Re: need new bushings... (JohnShiwota)
I have poly in my car.
you'll need a press for every bushing. The machine shop pressed out my old bushings from the control arms. I was able to install every poly bushing by hand except for the TA bushing.
It took me a day to install the es master kit and the TA bushings took 3 hrs.
Old Jun 24, 2006 | 08:52 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
synthetic bushings tend to wear out faster than the rubber. if your car is a street car, get the mugen set, it is said to be of higher durameter, yet retain the streetability.
i had replaced all of my bushings with sythetic, and after a couple of years noticed some wear.
for a race only car, Delrin is the way to go.
Old Jun 24, 2006 | 08:54 PM
Default Re: (Ash J. Williams)
another thing to consider, synthetic trailing arms bushings are believed to bind on a certain axis. which is why most racers tend to use the mugen part or go with a spherical delrin bushing for TA, at the least
Old Jul 2, 2006 | 06:02 PM
1990crxsir's Avatar
Is there a kit that you know of that has the derlin bushings?
Old Jul 2, 2006 | 06:04 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnShiwota &raquo;</TD></TR><TR><TD CLASS="quote">poly all the way. factory bushings do not alllow the suspension to pivot freely. </TD></TR></TABLE>Wait...wouldn't it be the other way around?
Old Jul 2, 2006 | 06:35 PM
george34's Avatar
Default Re: need new bushings... (dr_latino999)
Where can you buy the mugen bushings?
Old Jul 2, 2006 | 06:42 PM
Default Re: need new bushings... (george34)
Mugen Bushings
Old Jul 2, 2006 | 07:38 PM
george34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Mugen Bushings</TD></TR></TABLE>
Thanks
Old Jul 11, 2006 | 08:44 AM
JettCRX's Avatar
Yikes... that's going to be quite a bit pricier than the ES kit.
teambk8
May 2, 2009 08:02 AM
EFstyle
Jun 1, 2008 10:27 PM
maynards_ek
Oct 31, 2007 09:17 AM
litterbox
Oct 15, 2006 07:38 PM
lucas569
Dec 24, 2001 11:10 AM
