rear disc swap
i searched and i just need a refresher from an expert i have an entire 92 teg suspension ebrake cables included
i want to swap it all to a 91 CRX HF this will all work CORRECT ?
i was worried about the rear trailing arm length
thanks guy any pointers would help
i am doing the front i allready know the axles wont work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">It will work but you should get ebrake cables from a CRX Si, the Integra ones are too long (for a CRX).</TD></TR></TABLE>
Zip ties
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">im pretty sure it will all bolt up but not positive cause i rock the drums. for the front just get si axles.</TD></TR></TABLE>
I have front and rear DA brakes on my HF. I dont know if the si axels ft in the DA hubs? Dont forget the m/c booster and prop valve!
I am using DA axels, are they correct? I just did the swap and I am having issues with the passenger side front. It shakes hard when I accelerate. Ball joints? I dont want to replace anything unless I know it's broken.
Zip ties
awesome well now i can slowly and lovingly sand blast powder coat replace the bushings and all that jive while my crx runs around on its blown out **** getting 51 miles per gallon what a beautiful thing ... !!!
Maxcapacity
Jan 27, 2008 05:42 PM
