CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK?
Old Jun 23, 2006 | 04:23 PM
projectef's Avatar
Default CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK?
i deciding on if i should go built mini me or straight z6. the a6 has higher comp.. aftermaket pistond then the z6.
can i put d16a6 srp pistons in a z6 block? or i should just use the a6 block, w/the z6 head?
Old Jun 23, 2006 | 05:24 PM
slpnz6's Avatar
Default Re: CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK? (projectef)
P29 usdm integra pistons... high comp!!!
Old Jun 23, 2006 | 07:21 PM
hatchinprogress's Avatar
Default Re: CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK? (slpnz6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slpnz6 &raquo;</TD></TR><TR><TD CLASS="quote">P29 usdm integra pistons... high comp!!!</TD></TR></TABLE> is the "p29" teg the 1st gen?(with the d-series motor) if not the bore(from a b-series) would be too big to fit a b-series piston in a d-series block (d-series=75.00mm.....b-series=84.00mm(i think))
Old Jun 23, 2006 | 07:37 PM
silentdork818's Avatar
Default Re: CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK? (hatchinprogress)
P29 is 88-89 Integra D16A1 motor...75mm bore.
Old Jun 23, 2006 | 10:17 PM
goforbroke's Avatar
MEAT PATTY
You can put a6 pistons in your z6 block, what is the compression of the forged srp pistons?
Old Jun 23, 2006 | 11:55 PM
ExospeedAMcrx's Avatar
Default Re: CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK? (goforbroke)
Bore size is the same, BUT you have to consider when using pistons in different block and cylinder head combinations may have VALVE clearance issues.
Some cylinder heads have bigger valves than other heads. Also Valve angles are different for each cylinder head. You also have Dome shape matched to the cylinder heads combustion chamber. So its not necessarily wise to switch pistons used for different heads.
Old Jun 24, 2006 | 08:40 PM
projectef's Avatar
Default Re: CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK? (silentdork818)
i was wondering if the d16a6 pistons will fit in the d16z6 block. because i was going built d16z6, but i think i might go built mini me, because the srp piston for the a6 is 11-5-1 or 11-0-1, and the d16z6 is 10-5-1
Old Jun 24, 2006 | 08:58 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
the difference between the A6 and a Z6 is the head, specifically the volume of the chamber.
from what i remember the Z6 head's chamber is smaller than the A6 head
Old Jun 24, 2006 | 09:07 PM
Default Re: CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK? (Ash J. Williams)
you have to use the Piston that matches with the head you are using. the block you are using doesnt matter if its an A6, Z6 or Y8, its pretty much the same deck height and stroke.
What matters is:
1. Combustion chamber size
2. Valve size
3. Valve angle
Thats what determines the design of the piston.
Old Jun 24, 2006 | 10:52 PM
projectef's Avatar
Default Re: CAN I USE SRP D16A6 PISTONS IN A Z6 BLOCK? (exospeedAMcrx)
so i should just use the a6 block with da z6 head, cause the piston for the a6 is higher.
Old Jun 24, 2006 | 10:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectef &raquo;</TD></TR><TR><TD CLASS="quote">so i should just use the a6 block with da z6 head, cause the piston for the a6 is higher.</TD></TR></TABLE>
always CC your head, and clay the engine when assembling. nothing hurts more than having the piston hit the valves during the initial start-up.
Old Jun 24, 2006 | 11:14 PM
projectef's Avatar
aight man thanks
Old Jun 25, 2006 | 03:30 AM
91SiZ6's Avatar
Just a note, not that I doubt Exospeed in the slightest because Will knows his ****. There are people running the high dome P29 pistons with a .05" mill on the head and a Crower Stage 3 cam without any valve clearance issues...and they still have tunability.
If the SRP pistons give an 11:1 in an A6 that'll be about 12:1 in a Z6, just like P29 pistons. You will undoubtedly want to clay the motor to make absolutely sure of the clearances though.
Old Jun 25, 2006 | 06:48 AM
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">Just a note, not that I doubt Exospeed in the slightest because Will knows his ****. .</TD></TR></TABLE> that might be true, i just wish there was a way to reach them, i called them so many times when i was tryin to order my pistons and rods....but they would never get back to me (they would just pass the phone/order to another guy)
Old Jun 25, 2006 | 01:12 PM
91SiZ6's Avatar
Just going off of what I've seen of his posts on D-Series.org.
Old Jun 25, 2006 | 09:09 PM
projectef's Avatar
Default Re: (hatchinprogress)
yeah i have a zc block but ill jus stick wit the a6 block
Old Jun 26, 2006 | 11:40 AM
dohdoh420's Avatar
Default Re: (projectef)
all d16 SOHC bottom ends are the same except for the pistons.. so buy the pistons for wich head you are using.. the head is what makes the compression differences
Old Jun 26, 2006 | 12:24 PM
d16vtecx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> is the "p29" teg the 1st gen?(with the d-series motor) if not the bore(from a b-series) would be too big to fit a b-series piston in a d-series block (d-series=75.00mm.....b-series=84.00mm(i think))</TD></TR></TABLE>
b16,b17,b18= 81mm bore b20=84mm bore
just to clear this up
Old Jul 2, 2006 | 09:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> that might be true, i just wish there was a way to reach them, i called them so many times when i was tryin to order my pistons and rods....but they would never get back to me (they would just pass the phone/order to another guy) </TD></TR></TABLE>
I personally apologize for that. I dont know how that happened. My personal hours are noon to 8pm CA time, so if you have questions PM, email or leave your number with someone there so I can talk to you guys personally. I'm down to chat SOHC stuff whenever, dont have to buy from us. Just call me up if you have any questions or ideas.
Old Jul 2, 2006 | 12:51 PM
Default Re: (exospeedAMcrx)
Hey man Roy still has my ZC hybrid tranny...??? haha
singleslamman
Apr 10, 2008 05:24 PM
97grnrs
Apr 10, 2007 10:34 PM
Fuelslut
Dec 11, 2005 09:51 PM
douspray
Jun 24, 2005 10:35 AM
SLOAZZ95
15
Dec 10, 2003 09:25 PM
