high boost hondas, how often you change your sparkplugs????
Old Jun 23, 2006 | 01:01 PM
graphic's Avatar
Default high boost hondas, how often you change your sparkplugs????
i had a wierd power loss problem the other day @full boost, car was breaking up bad. i didn't know what to do, then i thought id check my plugs.
the electrodes were as thin as a needle. so i replaced the plug and the car pulled fine,
im making 380whp @ 18psi and the plugs only had like 3000 hard miles on them.
Old Jun 23, 2006 | 01:07 PM
boostfeen's Avatar
Default Re: high boost hondas, how often you change your sparkplugs???? (graphic)
wow. as long as your tune is good, meaning A/F and timing, then the plugs
should last a good amount of time, but not 3000 hard miles on a boosted car.
not saying they won't last that long, but something as cheap as plugs, IMO, should be changed way before that.
Old Jun 23, 2006 | 04:52 PM
DRAGLS's Avatar
Default Re: high boost hondas, how often you change your sparkplugs???? (boostfeen)
about once a year.
Old Jun 23, 2006 | 05:23 PM
B18 CYA's Avatar
my plugs are fouled out also. haven't put much mileage on it.
Old Jun 23, 2006 | 05:26 PM
komat's Avatar
Default Re: (B18 CYA)
2000miles
Old Jun 23, 2006 | 05:36 PM
non-VTEC's Avatar
i dont know why you guys go through so many plugs.......maybe i dont drive my turd hard enough but my plugs have been installed for over 10k miles and they still look great.
Old Jun 23, 2006 | 05:52 PM
vtec.dc2's Avatar
not high hp.. but i change them ~4-5k miles.. its well worth $7-8..
Old Jun 23, 2006 | 06:06 PM
sirguy01's Avatar
Default Re: high boost hondas, how often you change your sparkplugs???? (vtec.dc2)
my car before was putting down 260whp and i had to change mine every 2000 miles with a pretty good tune. It depends how you drive the car, i drive to school which is 4hrs away and usually after i come home from a trip the car is already being stupid a lot of sputtering and what not.
what plugs do you guys use?
Old Jun 23, 2006 | 06:09 PM
vtec.dc2's Avatar
Default Re: high boost hondas, how often you change your sparkplugs???? (sirguy01)
bkr7e.. or bkr7e11 whatever is in stock..
Old Jun 24, 2006 | 08:01 AM
boostfeen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirguy01 &raquo;</TD></TR><TR><TD CLASS="quote">
NGK
Old Jun 24, 2006 | 08:03 AM
boostedcivicsir's Avatar
Mr. Badwrench
i use NGK 2668's. ill use the ones from the previous rounds of eliminations, for qualifying, unless there is a problem, and def put new ones in before eliminations.
Old Jun 24, 2006 | 08:17 AM
ImportMotorSpec's Avatar
Default Re: high boost hondas, how often you change your sparkplugs???? (boostedcivicsir)
I always change them before an event, and maybe before eliminations if i feel like they might cause an issue. Also, before i hit the dyno, i throw new ones in. The new tune seems to be a lot better though. I have probably 15 passes on them an probably 400 miles on them.
Its a cheap thing to replace that might cost you in the long run.
Old Jun 26, 2006 | 01:00 PM
graphic's Avatar
Default Re: high boost hondas, how often you change your sparkplugs???? (ImportMotorSpec)
im using the ngk copper zfr7f-11
there only 1.98 ea.
Old Jun 26, 2006 | 01:13 PM
cyph3r's Avatar
ngks
change em with every oil change
FG_Coupe
Honda Civic (2006 - 2015)
Oct 26, 2007 05:29 PM
wpsadmin
Sep 9, 2005 01:40 PM
VTC_CiViC
Jan 31, 2002 12:03 PM
GruvyTune
Jan 21, 2002 07:06 PM
GoLowDrew
Nov 21, 2001 10:45 AM
