b18a1 swap questions(into 91 hatch)
Old Jun 23, 2006 | 09:09 AM
scanz89's Avatar
Default b18a1 swap questions(into 91 hatch)
well, i have a crappy d15 with the 4-speed manual trans, and its dpfi. i found a REALLY great deal on a complete engine/trans/ecu/wiring harness setup from a 90-91 integra. what whould i need to do for the swap other than the conversion from dpfi to mpfi on the chassis harness? do i need all the shift linkages and clutch cable as well? only thing it is missing is the dizzy, could i use the d15 dizzy cause they are both OBD0 or would i need to eat the $240 for a new one?
thanks in advance.
Old Jun 23, 2006 | 09:15 AM
Vantage's Avatar
everything sounds good, yes you will need shift linkage, it will need to be cut and welded, unless u get the hasport already done piece. You will also need mounts and other small misc things that will come up. I needed a new clutch cable, but most people dont, every swap is a bit different.
im sure if u search u can get an extensive list.
Old Jun 23, 2006 | 09:45 AM
Bseries!EF!hatch's Avatar
Default Re: (B18a_CRX)
If you want to save some money avid motorsports sells some motor mounts you can pick them up on ebay for about $247.00 plus shipping and they are just as good type in avid motor mounts on the search on ebay and you can take a look at them! good luck
Old Jun 23, 2006 | 12:52 PM
Slomies's Avatar
Default Re: (Bseries!EF!hatch)
what about the axles? will the integra axles this motor is coming out of fit? just an idea, i know the d-series axles dont fit the b-series swap
Old Jun 26, 2006 | 02:46 PM
scanz89's Avatar
well guys, i got the ENTIRE wiring harness from the engine to the fusebox and computer for $20!!!!! from a junkyard today, now all i need are the axles(still dont know which i need), the shift linkages, and the mounts. IM SO EXCITED!!! boost next year for shure!
Old Jun 26, 2006 | 03:29 PM
FernEF's Avatar
Default Re: (scanz89)
shift linkage *stated above*
mounts *stated above*
convert to mpfi
ecu and harness which u already have
since it was 4speed, u need either dx or si hubs
good luck, its a easy swap also
Old Jun 26, 2006 | 03:54 PM
sloweh3's Avatar
Default Re: (FernEF)
If you are interested, I've got some mounts and linkage for sale right now for a b-series ef. Since you are a trial user, email me at zcspeed145@hotmail.com. I'll sell them for a good price
hasty91ef
14
Mar 14, 2009 08:32 PM
kyle1jzsupra
Aug 29, 2008 02:57 PM
oldcarguy85
Jul 27, 2007 05:20 AM
90hatchb16
Nov 27, 2004 03:45 PM
