ECU
depending on mods. I'm guessing basically stock with some bolt-ons. If the P28 is programmed for your setup, use that. Otherwise just use the P72. Performance wise you're not gonna feel anything
P72 is better for full fonctionality.
The p28 will work but without IAB and knock sensor.
The knock sensor is there to protect your engine from pigning and the IAB to give you
low end torque. (80% @ 2500rpm)
SETI20
Aug 17, 2004 11:57 AM
