Honda S2000 Honda S2000
water leaks
Old Jun 23, 2006 | 12:49 AM
lucky13AP2's Avatar
Default water leaks
i was washing my S today, and when i get to the driver side window, on the top right where it curves, theres water leaking, im pretty sure someone else made a post about this or not, but i though i would jus ask, should i take my car into honda and see if its the drop top seal? or could it be anything? sorry if this is a repeat
Old Jun 23, 2006 | 02:45 AM
djnikko's Avatar
Default Re: water leaks (lucky13AP2)
Use some silicone lubricant on the rubber seal this should help. Do it every 6months or quarter of a year. Simply spray on leave for 30secs then wipe with a tissue (not removing all the lubricant obviously but so its not dripping). This has worked for me.
The other tip I find is dont undo the window whilst its raining, when you do it back up again I occasionally get a small water channel finding its way into the cabin.
Hope this helps
Old Jun 23, 2006 | 08:09 AM
jesseb01x's Avatar
my car does tha same thing. but its not much and only leaks after a wash, so i jus ignore it.
Old Jun 23, 2006 | 08:18 AM
TomTomTuning's Avatar
Default Re: water leaks (jesseb01x)
Yea my car might drip once or twice.. nothing major
i dont mind it
Old Jun 23, 2006 | 08:38 AM
Mr. Projekt's Avatar
* B A N N E D *
Adjust your windows.
Old Jun 23, 2006 | 12:34 PM
lucky13AP2's Avatar
Default Re: water leaks (FR-MOB: Projekt)
thanks guys, i had my windows adjusted and used some silicone lube both worked great, thanks again
Old Jun 23, 2006 | 01:02 PM
mykcuz's Avatar
yea i made that post, it happened from washing, in my case where the two pieces of weatherstripping meet a tiny part of the end had came off for some reason, so i just physically forced them together so they butt up, no more probs
Old Jun 23, 2006 | 08:32 PM
s2kb0i's Avatar
Default Re: water leaks (mykcuz)
how do you adjust the windows because mine drips a tad....
Old Jun 24, 2006 | 12:40 AM
* B A N N E D *
Default Re: water leaks (s2kb0i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kb0i &raquo;</TD></TR><TR><TD CLASS="quote">how do you adjust the windows because mine drips a tad....</TD></TR></TABLE>
Pick up a service manual. The diagrams are really helpful.
Old Jun 24, 2006 | 12:48 AM
s2kb0i's Avatar
service manual or owners manual? where can i obtain the "service" manual?
Old Jun 24, 2006 | 10:20 AM
* B A N N E D *
http://www.handaaccessories.com.
Old Jun 24, 2006 | 12:16 PM
Ross 2.0's Avatar
In a Junkyard near you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kb0i &raquo;</TD></TR><TR><TD CLASS="quote">service manual or owners manual? where can i obtain the "service" manual?</TD></TR></TABLE>
http://www.helminc.com
well worth the money for the use you will get out of it.
Old Jun 24, 2006 | 01:33 PM
nsxnext's Avatar
Shin-Etsu grease works perfectly for the seal. I forgot how much through the Honda dealer though.
Old Jun 28, 2006 | 06:39 PM
blankslat5's Avatar
vasoline works also. it expands the seal. My car doest leak at all even when i high pressure it at the car wash
oldskoolDA6
Oct 31, 2007 01:51 PM
awdgsx96
Oct 30, 2007 02:39 AM
pinks11
Oct 17, 2007 02:34 AM
DualCamDan
Aug 1, 2004 05:00 PM
StockTeg
Jun 24, 2003 12:27 PM
