question about drive shaft and axles for 97 prelude auto to manual swap.
Correct me if i'm wrong, but when i swap out my auto trans for a manual, i can use the same drive shaft and axles, correct? I do not need to buy a manual transmission starter either, do i?
Not to be disrespectful, but are you 100% sure? I ask because no other threads mention anything about the halfshaft or starter when they speak of the swaps.
i asked a tech at my work, and he said he believes that the middle shafts should be the same.
your tech is wrong.
44500-S0E-000 SHAFT ASSY., HALF (auto)
44500-S0A-000 SHAFT ASSY., HALF (5 speed)
maybe this will help you out:
http://www.mazmo.com/zameoj/swap.htm
D16SiHatch
Mar 4, 2008 02:29 PM
JUN.
Feb 5, 2008 02:41 PM
44500s0e000, 5sp, auto, automatic, axles, conversion, drive, driveshaft, half, manual, philapa, prelude, shaft, speed, trans
