2000 Golden Eagle Sleeved b20 shortblock.
Block with come with the following:
PRICE IS AT $75O FIRM!!!!!!!!!
Stock balanced crank, main caps, oil pan, windage tray, and oil pick up. ITR water pump and oil pump, water outlets and tubes, rear main seal, crank pulley and vtec oil line. no pistons or rods, bore is 84mm. room for improvement, nothing wrong with block and if you can find something in the pics that you have a question about, just ask. thnaks.
Modified by TypeSiR at 11:15 AM 7/7/2006
Modified by TypeSiR at 1:51 AM 7/19/2006
Modified by TypeSiR at 2:36 AM 7/25/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek910 »</TD></TR><TR><TD CLASS="quote">damage?</TD></TR></TABLE>
none at all. pistons had broken ringlands, no damage to cyclinder walls at all. plus its still 84mm, so even if you had to bore out you have some room for improvement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ixislikixi »</TD></TR><TR><TD CLASS="quote">i'll give u 600.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR »</TD></TR><TR><TD CLASS="quote">i would guess since the title says GE sleeved, its sleeved by GE.</TD></TR></TABLE>
Ditto
Ditto
