How can you tell if a fuel filter is clogged
Old Jun 22, 2006 | 07:05 PM
premo_si's Avatar
Default How can you tell if a fuel filter is clogged
I'm having a little trouble with my hatch, talking about it in this thread: https://honda-tech.com/zerothread?id=1663668 I have a stupid question about the fuel filter. How can you tell when it is plugged. So I took off the fuel filter today, and after I poured as much fuel out as I could, I put a rubber hose into the "in" hole and blew in. It felt like there was some resistance, like the air coming out should have been coming out a lot harder. I'm guessing that this means the filter is plugged up.
Old Jun 22, 2006 | 07:16 PM
J4k3's Avatar
Default Re: How can you tell if a fuel filter is clogged (premo_si)
Just replace it,its not that hard
Old Jun 22, 2006 | 07:35 PM
SIRX's Avatar
there should be no resistance at all. any and it is clogged
Old Jun 22, 2006 | 07:37 PM
rjay8604's Avatar
Default Re: How can you tell if a fuel filter is clogged (SIRX)
On my 87 Si, when the fuel filter was clogged, it actually acted like a rev limiter. It would rev without load, but it would cut off if you drove it with load up to i think it was 400 rpms.
adam00
Mar 11, 2010 09:31 AM
turboxsi
Jan 16, 2004 07:50 PM
sloaccord96
May 15, 2002 09:49 PM
