B16 oil pan and swap?'s
Old Jun 22, 2006 | 04:42 PM
frostwhitesi's Avatar
Default B16 oil pan and swap?'s
Hello.
I have a damaged drain plug in the oil pan of my B16. Any one know what US market oil pan will fit JDM B16?
Also found Moroso steel pan for B16 in King Motorsports for B16. Anyone try one of these? Will it fit JDM motor?
Anyone found a good way to fix stripped honda oil pan drain? It spins to a tight spot and does not leak but I want to either replace it or make a durable fix.
Also have some questions about unknown mounts that I have and a hasport linkage but would like to post some pictures with info. How do I post pictures with my post? Can't copy paste for some reason.
Thanks
Old Jun 22, 2006 | 09:45 PM
RCautoworks's Avatar
Default Re: B16 oil pan and swap?'s (frostwhitesi)
Yes they are interchangable
Old Jun 23, 2006 | 06:26 PM
US B16 interchangeable. What about other B series like LS GSR? All the same or not?
Thanks
Old Jun 23, 2006 | 06:33 PM
aXhatch's Avatar
ahve u tried just oversizing your drain plug? its not the end all of solutions, but it does work for a time. Enough time to get a new oil pan, maybe a moroso one?!!?
Old Jun 23, 2006 | 08:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostwhitesi &raquo;</TD></TR><TR><TD CLASS="quote">US B16 interchangeable. What about other B series like LS GSR? All the same or not?
Thanks</TD></TR></TABLE>
The bolt patten is the same
Old Jun 24, 2006 | 08:53 AM
BoostedEF's Avatar
Default Re: B16 oil pan and swap?'s (90blackcrx)
Just buy a new one its either like 120 from majestic or like 68 bucks from autozone.
Old Jun 24, 2006 | 08:55 AM
civicjdmb16a's Avatar
Default Re: B16 oil pan and swap?'s (BoostedEF)
i have a moroso i love it. You need to use their oil pick up if you use the pan with the kicked out back end.
Old Jun 25, 2006 | 08:11 AM
Default Re: B16 oil pan and swap?'s (civicjdmb16a)
The one I was thinking about is the OEM style made of steel. Its about $130. It would be worth getting if it has a stronger cut threaded drain instead of stamped for durability. Anyone know if this is the case? I'll have to check what my cost is on one from the dealer for comparison.
Thanks
Old Jun 28, 2006 | 06:46 PM
Anyone? Anyone?
Old Jun 29, 2006 | 07:08 PM
BoostedEF's Avatar
get the autozone one your going to dent and scratch it up anyway Id be pissed the first time I scraped going into the gas station or whatever if I bought a nice new pan for over 100 dallas
DelSol-B18
Sep 21, 2012 04:57 AM
JdelMsolG
Jul 13, 2008 05:26 PM
HighRevn
Jan 31, 2006 06:42 PM
eRACING
Nov 23, 2004 03:46 AM
curiousgpnoy
22
Jan 29, 2003 08:00 AM
