Is my clutch and flywheel for a Z6 or SI?
Old Jun 22, 2006 | 12:33 PM
pinecone's Avatar
Default Is my clutch and flywheel for a Z6 or SI?
Alright I am pulling my Z6 which has a 91 Si tranny attached to it. I didn't put the combo together just bought it like that.
Would the clutch and flywheel be for an Si or Z6? I know on some combo's you need to use either a clutch and flywheel for the motor or for the tranny.
So which would they be for?
Old Jun 22, 2006 | 01:38 PM
jlicrx's Avatar
Default Re: Is my clutch and flywheel for a Z6 or SI? (pinecone)
90 and up D-series flywheels are all the same - clutches are also the same, but 92 and up hydraulic clutch transmissions use a different throwout bearing than the earlier cable clutch transmissions - if you are buying a complete clutch kit, get it for the transmission you are using - in your case, you need the 91 Si clutch kit
Old Jun 22, 2006 | 02:07 PM
pinecone's Avatar
Default Re: Is my clutch and flywheel for a Z6 or SI? (jlicrx)
So I can reuse the clutch and flywheel in a 90-91 A6 or SOHC ZC? The reason I want to reuse them is because the tranny was rebuilt about 20-30k miles ago and there is no problems with the clutch and flywheel.
Old Jun 22, 2006 | 02:36 PM
jlicrx's Avatar
yes, you can use them
Old Jun 22, 2006 | 05:27 PM
pinecone's Avatar
Awesome, just what I wanted to know.
nitewolf
Nov 8, 2007 12:03 PM
EFstyle
Jul 21, 2007 04:22 PM
crx69
Apr 10, 2005 05:33 PM
-16V-
Dec 12, 2003 09:03 PM
LsTurbo91
Jul 6, 2002 10:01 AM
