What can it be? compression test: 225 240 241 242
head pnp resurfaced, new valves, valvetrain
block honed resurfaced, new pistons, rings
added an extra layer to a headgasket used only 50 miles, so it should still be good.
could it possibly need a valve adjustment?
could be the valves if you rings seated allready you shold be good to go. i would just keep driving it and dont really worry about it. as long as you speced your rings correctly you should have no problem
a good rule of thumb is that your lowest cylinder should be within 80% of your highest.
If its a fresh motor give it a little more time to seal up. Do a leak down test before you start worrying about anything.
valves are new... rings should be seated already... i have 200 miles... plus the dyno break in... im thinkin a valve adjustment?
Digital-R
Feb 19, 2002 08:52 PM
Digital-R
Feb 19, 2002 08:27 AM
