92 civic intake/head on 90 crx?
i got a 90 crx dx, and i got access to a 92 civic head/intake manifold. could i swap the intake manifold over so i can use mpfi instead of my dpfi? will the harness from the 92 swap over? will the head fit too? so i could get it worked and just swap it out? thanks!
Can you swap it yes, can you swap the harness no.
You will have to do the mpfi conversion and get an mpfi distributor and ECU. There are a couple for sale at hondamarketplace.com (hint hint).
You can use the injectors from the 92 also, you just will not need a resistor box.
well if the head will swap over just fine can i not just put my crx bottom end into this civic (d15b2)? because i bought the civic for 100$ cause it needed a new bottom end
thx
edit: I might have answered my own question, all 88-95 civic non-vtec had d15's right? so the bottom end will get my civic running since the head is still good. thanks anyways!
Modified by memorybox at 12:01 PM 6/22/2006
thx
tunerguy0985
Sep 7, 2011 01:16 PM
