Horrible bubbling !
'92 Hatch with B16A2.
AEM CAI
2.25" exhaust from header back
Kenji Chipped P28 ECU
After entering the freeway late last night, my car started this really awful bubbling sound. Kind of sounds like a WRX/STi that has exhaust. I took some video of it, but the video is 27MB and I only have 56k.
When at a stop it idles really rough and almost seem like it's going to die.
AEM CAI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 »</TD></TR><TR><TD CLASS="quote">Sounds like a dead cyl. Is it running rough?</TD></TR></TABLE>
Sure is. Any way I can do some kind of test here at home?
Pop the hood while the car is running, unplug one wire at a time.(plug it back in before you pull another). Do this until you do not notice a difference in it running. The one that you pull that does not make it run worse is the dead cyl.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 »</TD></TR><TR><TD CLASS="quote">Pop the hood while the car is running, unplug one wire at a time.(plug it back in before you pull another). Do this until you do not notice a difference in it running. The one that you pull that does not make it run worse is the dead cyl.</TD></TR></TABLE> Yep
Thats the way to go.
Well, uhh, I found the problem.
My dad just happend to have a compression checker. So I got everything set up, hooked up an air compressor to blow all the **** out away from the spark plugs so nothing would fall into the cylinder.
Popped my hood.....and one of my wires was disconnected from the distributor !
again ! Not sure how it happend... But everything runs better now.
.My dad just happend to have a compression checker. So I got everything set up, hooked up an air compressor to blow all the **** out away from the spark plugs so nothing would fall into the cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefast93sol »</TD></TR><TR><TD CLASS="quote">Awesome! glad you got it fixed.
Me too ! No car = No job !
</TD></TR></TABLE>Me too ! No car = No job !
just to be sure because i too want to test this on my motor. when i pull each plug the motor should want to die correct? AND the ones that doesn't sound like its dieing is the bad cylinder? is this right or did i get it backwards.
nipcup101
May 12, 2008 12:02 PM
eg crunkmonster
Apr 10, 2003 10:30 PM
