jdm fog lights .... parts i will need????? HELP
i'm in the process of buying jdm fog lights for my 1993 Prelude VTEC
i need to know what parts other than the lights themselves i will need.......
having a hard time figuring out through google
so far i think i need:
Fog Light Relay (is there a particular relay just for fog lights?)
Fog light switch
Wiring harness
should i be set after that?
Fog light switch
Wiring harness
any 4 pin relay. it connects underneath the steering column you will see it with blue electrical tape. u don't need a wire harness. they are already there.
besided the actual fog lights/bulbs/covers/bolts
u will need a switch but not the wire harness, the wire harness only extends the wires so that the relay can bolt where the cruse control is.
u will also need the relay which u can now find at honda for 50, or autozone or pepboys for only $5 - it is located in the fog light section.
this relay at pepboys/autozone clips in and also has the mounting hole(even though you don'ot need to mount it, just clip in and tape up.).
GSR_96814
Sep 21, 2006 01:42 AM
member99-00
Jul 4, 2004 09:43 PM
