tuff to shift after hard rain.
Old Jun 22, 2006 | 06:16 AM
extensioncordy's Avatar
Default tuff to shift after hard rain.
ok so i drove home last night in the pouring thunderstorm and i stayed in 4th gear (std) the hole way home then when i go to downshift and pull in my driveway i have to fight to get it into gear. also the car has a dc sports short throw shifter. never had a problem before with it tho
Old Jun 22, 2006 | 06:36 AM
EFwithS2000taillights's Avatar
My suggestion would be, that you should check underneath the car and see if the shifter socket is rusted. I know that rotors can rust up in one rain fall, so maybe the shifter socket is too?? just an idea....good luck
Old Jun 22, 2006 | 06:43 AM
ludesrv's Avatar
Default Re: (EFwithS2000taillights)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFwithS2000taillights &raquo;</TD></TR><TR><TD CLASS="quote">My suggestion would be, that you should check underneath the car and see if the shifter socket is rusted. I know that rotors can rust up in one rain fall, so maybe the shifter socket is too?? just an idea....good luck</TD></TR></TABLE>
Highly doubt it would rust up like that. Check the condition of your fluid. Sometimes a little bit of water gets inside the tranny (if the level of water is high it can go in from the vent tube) and it wrecks the gear oil instantly. After that I could see it being a little rough to shift.
Old Jun 22, 2006 | 08:21 AM
civicwagonman's Avatar
maybe a stick got jammed in the linkage?
---SPEED-DEMON---
Sep 16, 2008 09:18 AM
Hatchman98
Mar 20, 2007 10:51 AM
dohc_profile
19
Feb 15, 2007 07:43 PM
CTR-GSR
Feb 24, 2006 09:47 PM
danteisme
Oct 6, 2005 02:57 AM
