installing a cam
Old Jun 21, 2006 | 09:43 PM
speedysohc's Avatar
Default installing a cam
how hard is it to install an aftermarket cam on a sohc engine?
what kind of timing would i have to do?
how long would this process take?
what kind of gaskets or seals would i have to replace?
comments needed
Old Jun 22, 2006 | 12:06 AM
Bleedinh 99Si's Avatar
Default Re: installing a cam (speedysohc)
maybe about 3-5 hrs depends on how mechanically inclined you are ,having the right tools etc... If it was me I'd change the valve cover gasket just for piece of mind
Old Jun 22, 2006 | 05:26 AM
b18sihatch's Avatar
what type of cam? doing any valve or springs/retainer work?
Old Jun 22, 2006 | 10:11 AM
speedysohc's Avatar
its a comp cam stage 1
no valvetrain work being done...
i am gonn aput in a aem true time gear and a new timing belt
Old Jun 22, 2006 | 10:20 AM
speedysohc's Avatar
also i heard you needed to replace something called a cam seal ... is this true?
Old Jun 22, 2006 | 10:37 AM
slow ass si 1's Avatar
Default Re: (speedysohc)
you dont have to but its a smart idea to ahead and replace it
Old Jun 22, 2006 | 04:56 PM
drift4jesus's Avatar
Default Re: (slow *** si 1)
Don't forget to adjust your lash to the new cam and use PLENTY of assebly lube
Old Jun 22, 2006 | 08:16 PM
_BEN_'s Avatar
What single cam engine are installing the cam in? Get a copy of a helms manual for it.
And yeah buy a new cam seal. It is only a couple of bucks.
Old Jun 22, 2006 | 09:28 PM
speedysohc's Avatar
im putting it into a d16y8. and by adjusting the lash to the new cam does that mean timing it or what?
Old Jun 22, 2006 | 09:29 PM
speedysohc's Avatar
thnx for all the help guys
Old Jun 23, 2006 | 01:04 PM
_BEN_'s Avatar
Adjusting the valve lash means...
Making sure the clearance inbetween the follower(rocker) and the cam lobes is set correctly.
94c1v1cex
May 4, 2008 10:04 AM
94 IntegraLS
May 25, 2007 04:41 PM
cadougherty_67
Mar 6, 2005 06:11 AM
MaxSterling
Jul 11, 2003 04:16 PM
J-Spec EG Sleeper
Jan 9, 2003 09:23 PM
