How To: 96-00 Civic OEM Splashguard Install
Old Jun 21, 2006 | 07:08 PM
Eran's Avatar
HT White Ops
Default How To: 96-00 Civic OEM Splashguard Install
Here is my own little how-to for everyone installing the Honda Access Splash Guards on their 6th gen Civic. This how-to will work for any body style (coupe, hatch, and sedan), all the holes are in the same place. The only difference is how the rears are shaped (hatches are different from coupes/sedans).
Part Numbers:
96-98 2/4DR - 08P00-S01-101
96-00 3DR - 08P00-S00-100
99-00 2/4DR - 08P00-S01-102
Here's the rundown:
1. Gather all the splash guards, hardware, and tools:
Required Items:
2 Front Splash Guards (L/R)
2 Rear Splash Guards (L/R)
6 Self-Tapping Screws (Front)
6 Self-Tapping Screws (Rear)
4 Spring Nuts
2 Plastic Grommets
Required Tools:
Stubby Screwdriver and/or Offset Screwdriver (Phillips)
Jack and Jackstands
Lug Wrench
Lugnut Key (If Applicable)
2. Turn your wheel toward the side of your car that you are working on. This will allow you adequate room to install the splash guard. Note the location of the screw holes. Remove the screw denoted with the yellow arrow.
*NOTE* - If you still have your fender liner in place, there will be screws in each hole. If your kit did not come with the front hardware, reuse all these screws.
3. Gather three of your six self-tapping screws.
4. Mount up the splash guard and install the screws in the earlier noted holes. Make sure you you flush the splash guard up with the side skirt.
5. Repeat steps 2-4 on the opposite side of the car. Step back and admire your work. This is a good time to get a beer before starting on the rears.
6. Gather one rear splash guard, three self-tapping screws, two spring nuts, and a plastic grommet.
7. Jack up the side of the car you are working on. Secure with a jackstand.
**Never work under your car using only the jack as a support. This is very dangerous, not to mention stupid.**
8. Remove your rear wheel (unless you've got tiny hands and are using a really small offset screwdriver).
9. Push the plastic grommet into the square hole on the rear of the fender well. Slide the spring nuts over the very top and very bottom screw indentations on the bumper. With your screwdriver and a little bit of force, pre-thread the screws into the bumper. Remove the screws.
10. Mount up the rear splash guard, making sure the bottom lip of the bumper is in the channel groove.
11. Install the three self-tapping screws. Leave the bottom one slightly loose. Holding the splash guard by the bottom, press upward to flush it up with the bottom of the bumper. Tighten the bottom screw.
Mount your wheel back on the hub, and propperly torque your lugnuts. Jack the car up, remove the jackstand, and lower the car back onto the ground.
12. Repeat steps 6-11 on the opposite side of the car.
Congratulations, you have installed your factory splash guards!
Old Jun 21, 2006 | 07:27 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: How To: 96-00 Civic OEM Splashguard Install (Eran)
looks good, I always wanted them but worried that i would always scuff them while going over speed bumps and driveways. I have an OEM rear lip so now it would be pointless for me to get some since the rears wont fit. Whats the clearance from the front one to the ground by the way?
Old Jun 21, 2006 | 07:32 PM
Eran's Avatar
HT White Ops
Default Re: How To: 96-00 Civic OEM Splashguard Install (rukawa1one)
With my H&R Sport springs, I've got a little less than an inch.
They're urethayne though, so they're pretty flexible, and really strong.
Old Jun 21, 2006 | 08:20 PM
dohcVTECeg2's Avatar
Old Jun 21, 2006 | 08:26 PM
E46Kid's Avatar
Default Re: How To: 96-00 Civic OEM Splashguard Install (dohcVTECeg2)
nice, thinking about getting me some, to reduce the small dings i get from rocks while driving
Old Jun 21, 2006 | 08:59 PM
JayNev's Avatar
nice write-up, hope to use this soon. where did you get yours from?
Old Jun 21, 2006 | 09:20 PM
Eran's Avatar
HT White Ops
Default Re: (JayNev)
H and A Accessories. Here's the level of service you expect from them:
Last weekend I ordered 96-00 hatchie splash guards from H and A Accessories. They got here yesterday, and I was very suprised to find that they were not for a 96 hatch, but infact, for a 99-00 coupe/sedan. Needless to say, I was pissed. Upon further examination of the box, it appears that the parts sticker from Honda for the hatchie guards was STUCK OVER the original sticker for the 99-00 coupe/sedan sticker. So, steamed, I sat down at my desk and wrote:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
I received my "Civic 3DR Splash Guards" (96 SPLAS 472) today, and was very suprised when I found that the rears do NOT fit my vehicle. My vehicle is a 97 Civic 3DR. Upon further inspection of my friend's vehicle, these are NOT for my car, but rather for a 99-00 Civic 4-Door. The package has the sticker for the 4-Door part number (08P00-S01-102), but someone stuck the sticker for the 3DR part number (08P00-S00-101). This mistake comes at a pretty big disapointment to me. Please let me know how I can return these, ASAP. Thank you.
-Jason</TD></TR></TABLE>
And I went to bed pissed.
But come this morning, I was shocked. It was like a Christmas miracle. I recieved this email in response:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
I apologize for the problem, the part number center digits denote the body
style and the hatchback is "S00", but the way you are describing the label,
it sounds as if they were mislabeled or mis-boxed.
I'm having the correct guards shipped out directly from Honda's warehouse to
you, they should reach you within 10 days.
Please just dispose of the kit you received- or keep the ones that fit for
spares - we will not need them returned. Once again sorry for the problem
and any inconvenience.
Thanks,
--Bill
Bill@HandA-Accessories.com</TD></TR></TABLE>
It's official. H and A Accessories has the best customer service of any online shop I've ever dealt with. I reccomend to anyone looking to get great prices and great service for factory accessories :thumbs up
http://handa-accessories.com
Old Jun 21, 2006 | 09:31 PM
JayNev's Avatar
good to hear, definitely going to order then
Unjockable
Dec 5, 2014 10:56 PM
dfjr0926
Jan 31, 2014 12:46 PM
Duc_du
Northwest (Sales)
Nov 10, 2011 04:45 PM
310HPS2k
Mar 23, 2010 06:22 PM
ej1sick760
Aug 25, 2008 02:12 PM
