Stupid hood problem!
Old Jun 21, 2006 | 06:40 PM
eye.ha8.u's Avatar
Default Stupid hood problem!
I just took the hood of my CRX to do some body work and paint it. when I was putting it back on, everything went smooth except for when I went to shut it, its not latching down. I have taken all the bolts out, tightened them in difference sequences, left them loose, and even left the latch loose. It still will not close.
Any suggestions, I have never had this freakin problem before...
Old Jun 21, 2006 | 06:47 PM
si90rex's Avatar
Default Re: Stupid hood problem! (JayDeeEmVeeTek)
have u adjusted the hood spring on the hood
Old Jun 21, 2006 | 07:09 PM
eye.ha8.u's Avatar
Default Re: Stupid hood problem! (si90rex)
This is going to sound stupider than my problem, but how the hell do you do that?
Old Jun 21, 2006 | 07:14 PM
CoolRedXylophone's Avatar
ahh i have the same problem
Old Jun 22, 2006 | 01:44 AM
eye.ha8.u's Avatar
Old Jun 22, 2006 | 09:57 AM
QuarterMileMaster's Avatar
You actually have a little bit of play where the rear of the hood bolts to the brackets. Close your hood and see if you need to move forward or back and adjust the bolts to the brackets accordingly.
Old Jun 22, 2006 | 10:17 AM
philkehn's Avatar
I had the same problem... the cable wasnt hooked up correctly underneath, check your cable
Old Jun 22, 2006 | 07:52 PM
eye.ha8.u's Avatar
Default Re: (philkehn)
Alright so today I took off the latch, and then latched it to the front end... Then I layed the hood down. I took off the bumper so I can see under and I have about a half inch gap between the hood and the latch. Some how the hood, or bracket bent, I have no idea how the hell that happen, any thoughts on this?
Old Jun 22, 2006 | 07:58 PM
Rex-Si's Avatar
Default Re: (JayDeeEmVeeTek)
Yeah , you didnt have it lined up right before you slamed the hood.
nck1alex
Mar 9, 2010 03:21 PM
stevew84
May 30, 2008 08:38 AM
Jameson
Mar 13, 2007 04:55 PM
rokkmunkey
Jun 12, 2006 09:30 PM
2fast4udude
Mar 5, 2006 03:43 PM
