Hood Dampers installed on 90 Civic
I was looking for hood dampers but couldnt find any from Tein for a EF Civic. After looking around the net I found a company called Redline Tuning makes some for our cars! I bought the Elite set cause they look a bit nicer and I usually show my Civic. I wanted to post up some pics for you guys if anyone was looking for these. Here is there link to the EF dampers also...
http://www.redlinetuning.com/Q....html
Video clips "IF" they work
http://www.we-todd-did-racing....5NTQx
That is one cramped engine bay. Power steering battery and all. looks real functional though I like it. Do you have any idea how much those hood dampers weigh? The look like a worthy weight gain, stupid prop rods suck. I removed my rear hatch struts to save weight but these might actually be worth the weight they add.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart »</TD></TR><TR><TD CLASS="quote">That is one cramped engine bay. Power steering battery and all. looks real functional though I like it. Do you have any idea how much those hood dampers weigh? The look like a worthy weight gain, stupid prop rods suck. I removed my rear hatch struts to save weight but these might actually be worth the weight they add. </TD></TR></TABLE>
If you care so much about weight, go check out jenny craig
It looks nice, clean. Riveted tho? What if the hood needs to come off/up higher for le's say...engine replacement (cherry picker)? What do you do?
I'd rock some, if it wasn't 70$ for them. I can make my own.
.It looks nice, clean. Riveted tho? What if the hood needs to come off/up higher for le's say...engine replacement (cherry picker)? What do you do?
Follow the link and look at the instructions - looks like they would just pop out of balljoints on either end, if you needed to remove or open up the hood more. Though you'd have to be non-He-man about it so that you don't pop out the rivets.
Eric, I'll take you up on that bet!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">
No need I have a mountain bike. I plan to loose 20lbs or so by the time my car is back together. 155 is a good weight for me. I try to never buy anything untill after I investigate the weight. Unless it is a recesity or the only item available for the application. If you don't you could easily add weight to your car that is unnecesary. I removed my heat, and wipers for a reason, no need to put excess weight back in. Next goes my sunroof, and 89 doors. Yes I do care about weight. I also refuse to date any girl over 5'6" 105lbs.
.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 »</TD></TR><TR><TD CLASS="quote">I would be afraid of bending the very flimsy EF hood</TD></TR></TABLE>
The rivits would probally break before the hood would bend.
They weigh next to nothing, and are pretty strong suckers. I would NOT use them on a aftermarket hood like a CF or FG hood, the hood would swing open and knock you silly
When I close the hood it doesnt bend the hood at all, but I know what you mean the metal is kinda cheap on Ef's "All Hondas really". You can take them off really easy buy just taking a pin out takes 2 mins. Only thing is clearence, I had to play around with them a bit to have the hood close all the way
Charlie Moua
Dec 28, 2010 02:50 PM
