Baring a CRX
Old Jun 21, 2006 | 02:58 PM
junior40er's Avatar
Default Baring a CRX
so im gonna change my motor on my CRS si and want to know if anyone on the forum has a swapped EF that is Bar'ed and post what engine you used, change mani?, sensor?, head/block combination etc. pretty what it takes to pass inspection in CALIFORNIA. I bold it cause cali is a bitch for these things.
Old Jun 21, 2006 | 03:33 PM
sirrvanna's Avatar
Default Re: Baring a CRX (junior40er)
wat's a crs?
Old Jun 21, 2006 | 04:42 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Baring a CRX (sirrvanna)
CRS= crash restraint system aka airbag..
Now let's get back on topic..
Modified by 88DXCRX at 8:23 PM 6/21/2006
Old Jun 21, 2006 | 05:01 PM
Loserkidwac's Avatar
Default Re: Baring a CRX (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">CRS= crash restraint system aka airbag..
Thats the best modification I've ever seen.....
Old Jun 21, 2006 | 05:15 PM
SIred91's Avatar
Rainman
what the **** is that? hydrogen setup?
Old Jun 21, 2006 | 05:39 PM
Its me DUB's Avatar
Default Re: Baring a CRX (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">what the **** is that? hydrogen setup?</TD></TR></TABLE>
One of two things...
A) Portable meth-lab
or
B) Largest water bong known to man
Old Jun 21, 2006 | 05:56 PM
SIred91's Avatar
Rainman
Default Re: Baring a CRX (doitdub)
I know who I am inviting to my next beach party!
Old Jun 21, 2006 | 06:06 PM
88DXCRX's Avatar
It is a bar man...
a portable keg set-up complete with tap..
Old Jun 21, 2006 | 06:07 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">so im gonna change my motor on my CRS si and want to know if anyone on the forum has a swapped EF that is Bar'ed and post what engine you used, change mani?, sensor?, head/block combination etc. pretty what it takes to pass inspection in CALIFORNIA. I bold it cause cali is a bitch for these things.</TD></TR></TABLE>
What in the world are you talking about? What is "Bar'ed", and what is this inspection stuff you speak of? I'm confused. Is an inspection like another word for car show or something, if so car shows are gay. Do you have to have a certain type of motor to enter the inspections or something? What is going on here?
Old Jun 21, 2006 | 06:26 PM
91SiZ6's Avatar
BAR = Bureau of Automotive Repair.
You can run pretty much any engine you want as long as it's available in a USDM model car, you convert OBD where neccessary, and you run the motor and chassis fuel and emissions correctly. Any external mods should be CARB Cert. only. Also, it's a Federal emission law that the motor has to be the same year as the chassis or newer, it can't be older than the chassis.
Old Jun 21, 2006 | 06:40 PM
91B16HF's Avatar
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">BAR = Bureau of Automotive Repair.
You can run pretty much any engine you want as long as it's available in a USDM model car, you convert OBD where neccessary, and you run the motor and chassis fuel and emissions correctly. Any external mods should be CARB Cert. only. Also, it's a Federal emission law that the motor has to be the same year as the chassis or newer, it can't be older than the chassis.</TD></TR></TABLE>I think this only really applies in California, we don't have to do none of that here in Md.
Old Jun 21, 2006 | 08:28 PM
west nile's Avatar
Default Re: Baring a CRX (Loserkidwac)
That pic is hilarius!
Anyway, I have a b16 in my crx, and let me be the first to tell you that the baring process sucks! But can easily be done. It is so stupid, if the car will pass smog than what does it f....in matter!!!
Ok, so first off I have a JDM B16 1st gen. You need to convert all the smog stuff over to 94 Del Sol b16a3 stuff. So that means P30 ECU=converting to obd1, b16a3 throttle body with map sensor mounted on top...yes they did check mine and I failed, have to go back, but I knew that was coming. Also Del sol intake manifold, but I just used Skunk2, mount the carb stickers in the engine bay. Del sol intake, I would just use an aem intake, or I have heard though that some ref's don't trip off of stock boxes or arms, actually I don't think they would know how to tell. I am also putting in a purge control from a del sol just to be safe so it looks exactly like the del sol in case he pulls out his vacuum diagram again, just going to locate it on the firewall like the crx one is. Charcoal canister, but I don't know how the ref would know the difference, one on the vacuum diagram I have looks exactly like my crx one. Will need to run a 4 wire o2 with the p30 obd1 setup. Need an obd1 distributor, go with distributor king. B16a3 headers, I went with DC just because it was the easiest to get my hands on. Make sure you have your wire jumper set up so can check ecu codes. Oh and keep all your papers and recipts, organize them in a folder or something!!! Call 1800-622-7733 and make yourself an appointment. I think that is about it.
This is all just for getting the car bared, not to mention parts that you should replace on doing an engine swap seen here...
http://www.norcalcrx.org/droppedcrxsi/B16a.htm , that is all the stuff I changed over, some costed a pretty penny from the dealer too.
Honestly....and I know almost everyone would say no way, but I say if you don't have to just keep the motor you have, especially if this is your daily driver. Yeah, the b16 in my crx is f..in fast and I get about 27mpg, but a lot of unexpected crap came up, especially all the barring stuff. The engine vibrates like crazy from the engine mounts. The J1 tranny sucks on the highway in 5th doing 80mph's at 5000rpm!, but most people just throw in a LS 5th gear.
If I were to do it again, I would have spent the 5K I invested and just rebuilt the motor/tranny, end of story.
Old Jun 21, 2006 | 08:29 PM
west nile's Avatar
damn, I wrote a staight essay.
oh yeah forgot to mention, I got a d16z6 throttle body, that I am going to have bored out to 60mm by maxbore, it is just like the b16a3, just bore is smaller.
Old Jun 22, 2006 | 07:10 AM
CRX Toad's Avatar
Default Re: Baring a CRX (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">
What in the world are you talking about? What is "Bar'ed", and what is this inspection stuff you speak of? I'm confused. Is an inspection like another word for car show or something, if so car shows are gay. Do you have to have a certain type of motor to enter the inspections or something? What is going on here?</TD></TR></TABLE>
Bart you are silly.
I'm glad, there you go Bart there is the answer. Put that down in your little book next to what JDM, USDM, and CRX means.
Old Jun 22, 2006 | 07:16 AM
CRXBart's Avatar
Default Re: Baring a CRX (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">
Bart you are silly.
I'm glad, there you go Bart there is the answer. Put that down in your little book next to what JDM, USDM, and CRX means. </TD></TR></TABLE>
Bwahahahahahahahaha
Old Jun 22, 2006 | 07:53 AM
junior40er's Avatar
Default Re: Baring a CRX (west nile)
thanks for the info. but I wanna change cause I changed headgsket and still mixes water with oil and vice versa.
Old Jun 22, 2006 | 10:29 PM
91SiZ6's Avatar
Default Re: (91B16HF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I think this only really applies in California, we don't have to do none of that here in Md. </TD></TR></TABLE>
And the original poster happens to be in California.
GHETTOassREX
Oct 5, 2007 03:32 AM
George Knighton
67
Apr 25, 2007 11:11 AM
thirteen20CRXSi
Feb 2, 2007 01:56 PM
whiteguyndahood
Nov 4, 2006 07:49 AM
dipset18
Oct 3, 2004 09:14 AM
