ECU Codes
Old Jun 21, 2006 | 11:40 AM
J4k3's Avatar
Default ECU Codes
I figured I'd make this thread to help people with ECU codes so they dont have to make a seperate thread since some cant search.
1- O2A - Oxygen sensor #1
2- O2B - Oxygen sensor #2
3- MAP - manifold absolute pressure sensor
4- CKP - crank position sensor
5- MAP - manifold absolute pressure sensor
6- ECT - water temperature sensor
7- TPS - throttle position sensor
8- TDC - top dead centre sensor
9- CYP - cylinder sensor
10- IAT - intake air temperature sensor
12- EGR - exhaust gas recirculation lift valve
13- BARO - atmospheric pressure sensor
14- IAC (EACV) - idle air control valve
15- Ignition output signal
16- Fuel injectors
17- VSS - speed sensor
19- Automatic transmission lockup control valve
20- Electrical load detector
21- VTEC spool solenoid valve
22- VTEC pressure valve
23- Knock sensor
30- Automatic transmission A signal
31- Automatic transmission B signal
36- Traction control (found on some JDM ECUs)
41- Primary oxygen sensor heater
43- Fuel supply system
45- Fuel system too rich or lean
48- LAF - lean air fuel sensor
54- CKF - crank fluctuation sensor
58- TDC sensor #2
61- Primary oxygen sensor
63- Secondary oxygen sensor
65- Secondary oxygen sensor heater
71- Random misfire cylinder 1
72- Random misfire cylinder 2
73- Random misfire cylinder 3
74- Random misfire cylinder 4
Old Jun 21, 2006 | 11:47 AM
ludesrv's Avatar
Default Re: ECU Codes (J4k3)
The FAQ has this info in it!
Old Jun 21, 2006 | 02:24 PM
J4k3's Avatar
Default Re: ECU Codes (ludesrv)
Oh dang i didnt know. I just see a lot of. OMG OMG can you help me, my ecu is flashing and i cant read my cel. Saves everyone from having to post.
Old Jun 22, 2006 | 02:14 AM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J4k3 &raquo;</TD></TR><TR><TD CLASS="quote">I figured I'd make this thread to help people with ECU codes so they dont have to make a seperate thread since some cant search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">The FAQ has this info in it!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J4k3 &raquo;</TD></TR><TR><TD CLASS="quote">Oh dang i didnt know. I just see a lot of. OMG OMG can you help me, my ecu is flashing and i cant read my cel. Saves everyone from having to post.</TD></TR></TABLE>
where? i just looked through 5 pages in the EF section. i dont see that topic at all.
cookie points for the effort though.
Old Jun 22, 2006 | 07:03 AM
court's Avatar
25 Year Member
Default Re: ECU Codes (STREETWERKZ)
google honda ecu codes
Old Jun 22, 2006 | 07:08 AM
Loserkidwac's Avatar
Default Re: ECU Codes (court)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court &raquo;</TD></TR><TR><TD CLASS="quote">google honda ecu codes</TD></TR></TABLE>
Old Jun 22, 2006 | 07:23 AM
J4k3's Avatar
I haven't seen one in about a week but i know at least once a month i end up telling someone on here what the code means.
Old Jun 22, 2006 | 07:30 AM
Don't hand feed those losers that can't figure out how many times there light blinks and look through the 8 billion webpages on line that tell them how to read the code and figure out what it is...if they can figure out how to make a thread on H-T they can figure out how to find them on google
Old Jun 22, 2006 | 07:31 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J4k3 &raquo;</TD></TR><TR><TD CLASS="quote">I haven't seen one in about a week but i know at least once a month i end up telling someone on here what the code means.</TD></TR></TABLE>
That's a giving cause no one searches and no one goes in the FAQ. I told the mod about maybe forcing the new subcribers for the first month to only see FAQ of each forum, FORCING THEM TO READ THROUGH THEM cause more then likely there question will be answered in there.
Old Jun 22, 2006 | 07:57 AM
HU MAN CHU's Avatar
some of the stuff in the faq isnt clear for some noobs, and they have to ask someone for clarification, and if they didnt ask then theyd come back later after they f something up asking even more stupid questions so i say let them ask
Old Jun 22, 2006 | 08:03 AM
J4k3's Avatar
Default Re: ECU Codes (HU MAN CHU)
Maybe this should just stay at the top and be titled:
"Look here if you're too stupid to search for how to read your little blinking light"
Old Jun 22, 2006 | 08:06 AM
HU MAN CHU's Avatar
well not everybody is a professional mechanic man
» No Results Found
Your search for how to read the little blinking light returned no results.
Please try different search criteria or a different data set.
The following words are too short or too common and were not included in your search: the, to, little, how.
» Go Back
Old Jun 22, 2006 | 08:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J4k3 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe this should just stay at the top and be titled:
"Look here if you're too stupid to search for how to read your little blinking light"</TD></TR></TABLE>
Good idea change the title
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HU MAN CHU &raquo;</TD></TR><TR><TD CLASS="quote">well not everybody is a professional mechanic man
» No Results Found
» Go Back
You don't need to be a professional mechanic to work on a Honda
Old Jun 22, 2006 | 08:10 AM
HU MAN CHU's Avatar
Default Re: ECU Codes (Loserkidwac)
true, but you cant expect people to know everything
Old Jun 22, 2006 | 08:17 AM
No no I don't...thats not the problem, there is so much info on this site and all over the internet, with 5 min of searching you could DL a honda repair manual that includes the ecu code list and how to fix the problem...after you do that and if dosen't work then make a post...
Noobs tend to be to lazy to search for basic easy things, thats the argument
Noob quote of the centruy "I searched (my pants) and I couldn't find anything"
Old Jun 22, 2006 | 08:18 AM
HU MAN CHU's Avatar
thread jacking here but, what sites you use for the repair manuals
Old Jun 22, 2006 | 08:25 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HU MAN CHU &raquo;</TD></TR><TR><TD CLASS="quote">thread jacking here but, what sites you use for the repair manuals</TD></TR></TABLE>
I have the helms in a PDF format at home.
91ef8sir
20
Jan 29, 2013 11:24 AM
JeDiMaster
10
Oct 15, 2010 06:00 PM
GreenMachineRex
Dec 24, 2004 04:56 PM
Audi A4
Apr 21, 2004 08:45 AM
BLuDoHcReX
Apr 3, 2003 07:36 PM
