Small leak from prop valve connection (sealant question)
Old Jun 21, 2006 | 08:01 AM
Prod's Avatar
Default Small leak from prop valve connection (sealant question)
Just got done converting my car to discs all around. I have a small annoying leak from two of the prop valve connections which is making me add a little brake fluid every couple days.
I've had a mechanic tell me to just tighten the hell out of them with a brake line wrench which doesn't seem right to me so I am curious if theres some sort of liquid gasket type product for brake lines which I could use on the threads ? I can't seem to find one, don't know if they exist.
If theres no gasket type product, what would be your recommendation ?
Old Jun 21, 2006 | 08:07 AM
tatmark1's Avatar
Default Re: Small leak from prop valve connection (Prod)
i say try tightening them down more too
Old Jun 21, 2006 | 08:26 AM
john666's Avatar
cant you use plumbers tape ? i would imagine tighten it more tho
Old Jun 23, 2006 | 09:44 PM
Prod's Avatar
Default Re: Small leak from prop valve connection (john666)
Don't know about the plumbers tape, I think the brake fluid might just destroy it over time....Guess I'll just tighten the **** out of them
nicky352
Dec 15, 2010 07:32 AM
jdm inc
Oct 30, 2010 11:41 PM
civicnoob
Apr 28, 2009 09:07 AM
pcguy760
Jun 26, 2007 08:57 AM
GetawayInMoscow
Aug 18, 2005 11:51 AM
