91 dx wiring diagram
Old Jun 21, 2006 | 06:18 AM
projsectEF's Avatar
Default 91 dx wiring diagram
does anyone have a 91 civic dx wiring diagram?
my car won't start and I know I'm getting spark.
My injectors won't spray and I can't figure out why.
I know that they're not clogged and I am getting fuel.
I think its the wiring.
can anyone help me. what could cause my injectors to not spray when tryin to start the car?
Old Jun 21, 2006 | 06:22 AM
mntuner2's Avatar
Default Re: 91 dx wiring diagram (projsectEF)
If you are getting spark chances are the ecm is seeing a reference signal to switch injectors on/off. Is there any codes? Have you used a noid light on your injector harness. Is it a MPFI conversion?? Need more info.
Old Jun 21, 2006 | 09:54 PM
projsectEF's Avatar
Default Re: 91 dx wiring diagram (mntuner2)
What is a noid light? is that the same as a test light?
I swaped in a d16z6 motor if that helps any.
When I inject fuel into the intake chamber it starts right up then dies.
can you tell me what can cause the injector to not spray?
Old Jun 21, 2006 | 09:57 PM
philkehn's Avatar
Well again when you put the new engine it did you do your DPFI to MPFI?
http://hybrid.honda-perf.org/t...g.htm <--- If not heres how to do it check your wires...
Old Jun 22, 2006 | 07:27 PM
projsectEF's Avatar
Default Re: (philkehn)
My car already came with the mpfi conversion. the car was running with the old motor.
are there any sensors that would cause the fuel injectors to not spray when cold starting?
mugen12_35sec
Jun 3, 2008 08:31 PM
BIG RICH
Sep 16, 2006 11:55 AM
lilbc1390
Sep 4, 2005 01:41 PM
geoff19crx
May 31, 2003 08:19 AM
neiloneil03
Sep 14, 2002 04:28 PM
