ZERO low end power, ok top end, intermitant.
Old Jun 21, 2006 | 04:47 AM
juevi (old)'s Avatar
Default ZERO low end power, ok top end, intermitant.
94 Civic EX with over 250k on it. I got this kids car last night so haven't got to check too much yet, however, I thought I'd run this past you guys first. This car has NO power in the lower end, sometimes you have to slip the clutch like mad to even get it to move. Above 4500 it seems to make adequate power. He DOES have a vtec code. Is it possible for it to be stuck on vtec on? I did a search and there was some argument.
Is there anything else you guys have ran into? I have not had a chance to check the Cam/Ignition timing yet, I will later today, however, I feel that is not too much of an issue because it was intermitant at first, somedays ran good, some not. It just sucks all the time now. Thoughts?
Old Jun 21, 2006 | 04:51 AM
TorquelessB16's Avatar
Default Re: ZERO low end power, ok top end, intermitant. (juevi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juevi &raquo;</TD></TR><TR><TD CLASS="quote">This car has NO power in the lower end</TD></TR></TABLE>
Welcome to the N/A SOHC world. But a quarter million miles, you're lucky it goes at all IMO.
Old Jun 21, 2006 | 04:55 AM
Default Re: ZERO low end power, ok top end, intermitant. (ZeeSix)
Ya I understand it's a high mileage car, and a honda, but there is something wrong with this thing, it's not right at all. It makes too good of power on top end to just be low compression or mileage related.
Old Jun 21, 2006 | 06:12 AM
EG2Driver's Avatar
do a leakdown test. See if you have good compression. If you do, then do a tune up (wires, plugs, dizstributor cap/rotor, oil, air filter...etc)
Old Jun 21, 2006 | 07:42 AM
littleredcivic's Avatar
if he has a vtec code, it is possible that the vtec is engaged and would cause crappy low end. disconnect the vtec lead at the head and try again, just DO NOT rev over 4500.
Old Jun 21, 2006 | 08:53 AM
Default Re: (littleredcivic)
Why not rev about 4500 with v-tec disconnected? It's just running on the smaller lobe. What am I missing?
Old Jun 21, 2006 | 09:01 AM
prison_snitch's Avatar
just get the code fixed and it will fix your problem. you're bogging out
CaliforniaHighwayPatrol
29
Jul 26, 2005 01:42 PM
Doom325
Apr 24, 2005 04:54 PM
accordselux
Mar 13, 2004 08:25 AM
2000_type_sh
Nov 19, 2002 05:59 PM
tr4il
Honda Motorcycles
Jun 24, 2002 10:44 PM
