Interchangable VSS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran »</TD></TR><TR><TD CLASS="quote">yes. search, since i posted this same question myself. lol</TD></TR></TABLE>
actually any b or d will work as long as its electronic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC »</TD></TR><TR><TD CLASS="quote">
actually any b or d will work as long as its electronic</TD></TR></TABLE>
Isn't there something about you have to switch the gears or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
Isn't there something about you have to switch the gears or something?</TD></TR></TABLE>
No
No
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1994CivicGS-R »</TD></TR><TR><TD CLASS="quote">so which one do i need for a b16?</TD></TR></TABLE>
is it electronic or cable? in other words, is there a clip from the harness going to it or a long plastic coated wire?
whatever it is...re-read the responses
I call BULLSHIT.
I have a 99 GSR transmission, 1993 D16Z6 VSS and it's NOT interchangable. The bottom part of the D16Z6 one is too deep to fit in the GSR tranny.
So maybe they're either different from OBD1 to OBD2 or B18C from anything else, but they are definitely not 100% changable from electronic or cable, because both of my VSS's are electronic and they are NOT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Essenar83 »</TD></TR><TR><TD CLASS="quote">I call BULLSHIT.
So maybe they're either different from OBD1 to OBD2 or B18C from anything else, but they are definitely not 100% changable from electronic or cable, because both of my VSS's are electronic and they are NOT.</TD></TR></TABLE>
I'll find out this weekend. (gonna try to use the old Z6 VSS onto my friends GSR trans)
you bitch at me for telling someone to search, but you do the same, who's the hypocrite?
i know why your mad, because people like me tell you to search all the time, that makes perfect sense now.
first person i have heard of saying that an electronic vss wouldn't work in a tranny, i am using a vss from a d15b8 in my second gen b16a. the only difference i saw was that the gear for the b16a one was metal while the gear on the b8 was plastic, both worked the same. i swapped them because i was getting a code, and when it threw the code again found out it was the wiring.
Do you have a digital camera? Just to update, VSS are interchangable, but you have to use the entire VSS, shaft, gear and everything, not just the unit which is what I was trying to do.
Show pictures cuz my D16Z6 VSS looked exactly like my GSR VSS, bolted on and everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Essenar83 »</TD></TR><TR><TD CLASS="quote">Do you have a digital camera? Just to update, VSS are interchangable, but you have to use the entire VSS, shaft, gear and everything, not just the unit which is what I was trying to do.
Show pictures cuz my D16Z6 VSS looked exactly like my GSR VSS, bolted on and everything.</TD></TR></TABLE>
I thought so.
I thought so.
This is what I needed. My S4 tranny vss got busted in shipping (lazy pisspoor shipper) and I was going to strip my vss of my d15b8.
Also will the slave cylinder from my b8 fit the S4 hydro tranny because the tranny mounts are the same?
RS2 FAB
Welding / Fabrication
Feb 10, 2008 12:28 PM
dragonfly2k3
Aug 8, 2007 10:15 AM
RACEPAK
37
Apr 7, 2005 04:45 PM
