manual fan switch problem
Old Jun 20, 2006 | 09:17 PM
jakscivic's Avatar
Default manual fan switch problem
Yo, I saw some posts of it on here and how to do it. So i went and bought 16 gauge wire and a switch that lights up when its on. So first i just clipped the wires at the plug for the fan motor. found out which was posotive and which was negative. ran a long wire to the inside of my car to the switch and soldered it on there. then ran a ground from the switch to my car. then ran a hot wire from my battery to the switch. And for grounding the negative i grounded the wire to the battery holder on bare medal. So i flipped it on and it came one, i was happy as hell. so i heat shrinked everything and tried to turn it on again and it didnt go on. i looked at all the ground and everything and tried to flip it on again, the light came on on the switch then turned off with out me turning it off. So i tried to flip it on again and it didnt turn on. does anyone know what might be wrong? car in my sig.
Modified by jakscivic at 10:46 PM 6/20/2006
Old Jun 20, 2006 | 10:48 PM
jakscivic's Avatar
need some help please
Old Jun 21, 2006 | 12:16 PM
jakscivic's Avatar
help?
Old Jun 21, 2006 | 12:56 PM
JimBlake's Avatar
Default Re: manual fan switch problem (jakscivic)
I don't think you want to do anything with the battery. The switch should simply jumper between the 2 wires on the fan switch. Maybe you blew a fuse?
Old Jun 21, 2006 | 02:23 PM
jakscivic's Avatar
what "hot" wire should i use then? I dont know about blowing a fuse or not. the fan wouldnt turn on then the switch stopped working. i didnt have an inline fuse connected to it, which i picked one up today. So i will put that in and try and find another hot wire to use.
Old Jun 21, 2006 | 03:40 PM
JSPECSIR's Avatar
Default Re: (jakscivic)
why dont you fix the problem with your fan so it works the way it was designed?
Old Jun 21, 2006 | 03:46 PM
jakscivic's Avatar
because i have an obd1 block with an obd0 wireing harness. so i dont have the plug to go into the fan switch on the thermo housing. so there for my fan doesnt turn on, and in turn my car over heats
Old Jun 21, 2006 | 04:33 PM
JSPECSIR's Avatar
you can go to an auto parts store and buy a fan wiring kit that comes with a relay and a thermostat that goes through the radiator , or in the coolant hose. these work great. also if you have ac they hook to the compressor 12v line. or you can get an adapter where you cut your rad. hose and it goes where you cut it and it holds a fan switch. also try http://www.summitracing.com
Old Jun 21, 2006 | 04:42 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jakscivic &raquo;</TD></TR><TR><TD CLASS="quote">what "hot" wire should i use then?</TD></TR></TABLE>None. The fan circuit has it's own power. All you're doing is closing a switch.
Take a wire & tap into each of the 2 wires of the OEM fan switch, without disconnecting those wires from the OEM switch. Take those 2 wires, run them thru the firewall, & hook them up to your switch.
This way, you leave the fan switch hooked up, so it can switch your fan on even if you 'forget' to use your manual switch.
Even though you don't have the right plug for that switch, you can still make some kind of connection to it. Or maybe you can get a fan switch to match your wiring, & maybe it'll have the same thread to install into the thermostat housing.
Modified by JimBlake at 8:53 PM 6/21/2006
98ej8coupe
Jul 30, 2008 10:07 PM
jakscivic
20
Jul 6, 2006 12:52 PM
slowassciv33
Sep 26, 2005 03:11 PM
hatchinprogress
20
Aug 14, 2004 05:50 PM
TylerB
Jul 11, 2004 08:02 PM
