JDM Integra Front End HID ballast???
Old Jun 20, 2006 | 12:34 PM
JDM_Risa's Avatar
Default JDM Integra Front End HID ballast???
the day i fear most has came... my hid ballast is shot...does anyone know where i can purchase one ballast for the jdm integra front....i really don't want to buy a pair of hid headlight...cause they aren't cheap
if anyone knows of a site or anyone place selling them let me know
Thank You
Old Jun 20, 2006 | 01:03 PM
Alexander's Avatar
Default Re: JDM Integra Front End HID ballast??? (JDM_Risa)
Check HIDplanet.com
You should be able to pick up an aftermarket ballast (philips for example) that will work perfectly.
Old Jun 20, 2006 | 01:18 PM
YumVTEC's Avatar
how did you fry a ballast, and are you sure its the ballast? i have arc'ed and reversed the polarity on the wiring for a number of ballasts and never had any of them go out. bulbs yes, they do go bad, but i've never seen a bad ballast.
the second poster is correct, you can use any ballast you want, but it won't be as clean as OEM, as you'd have to remove the OEM ballast and ignitor assembly, then mount up some aftermarket parts. plus the output might not be the same as the other side. your best bet is to find someone that has a single headlamp assembly for sale and buy that.
Old Jun 20, 2006 | 04:54 PM
JjuuN R's Avatar
Old Jun 20, 2006 | 04:59 PM
tommymoose's Avatar
Damn your car is quick
Goodluck on the fix, I hope this never happens to mine. If its consistantly that one side, have you used a testlight to check for current? If the wiring was done shoddy something could have come loose.
Old Jun 20, 2006 | 05:24 PM
JjuuN R's Avatar
Default Re: JDM Integra Front End HID ballast??? (tommymoose)
+ invest in some traction bars to keep the wheel hop to a minimum
Old Jun 20, 2006 | 05:42 PM
SuckMyDOHC's Avatar
contact niki tam at acutech in south san francisco. he could probably get you a whole brand new one if not used
Old Jun 21, 2006 | 06:05 PM
JDM_Risa's Avatar
Default Re: JDM Integra Front End HID ballast??? (SuckMyDOHC)
i have DTR traction bar... all prothane inserts...Avid Solid Rear Mount...
BobGnarly
Feb 1, 2005 05:38 PM
jdm phantomx
Dec 29, 2004 02:16 AM
JdmFront619
Dec 24, 2003 12:39 PM
