2000 si ECU fuse keeps blowing
Old Jun 20, 2006 | 12:28 PM
importeclipsegst's Avatar
Default 2000 si ECU fuse keeps blowing
as the title states, i have a 2000 turbo civic si that keeps blowing the 15amp ecu fuse underneath the hood. the car has been turbo for about 3 years now and the set-up has never been changed. i was wondering if anyone has had this problem before with there car and what was wrong with it. the first time it happened i just replaced the fuse and it worked fine for about a week and it did it again. when i replaced it the 2nd time everytime i put a different fuse in it would blow as soon as i tried to start the engine, but if i just turned on the key i can hear everything powering up(fuel pump realy, and fuel pump etc...) so any help is appreciated!
Old Jun 20, 2006 | 02:43 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 2000 si ECU fuse keeps blowing (importeclipsegst)
more than likely ....you have a GROUNDING ISSUE. One or more of your sensors is coming into contact with your car's chassis or ground/metal. Best thing to do is look around your motor for such things. Start out @ your O2 sensor...trust me on this one.
jakscivic
Oct 26, 2023 05:17 PM
simers
Jan 5, 2016 04:32 PM
timeverlastfan
Jun 8, 2015 09:23 PM
CRV4x4
Honda CR-V & Element
16
Dec 31, 2013 04:59 AM
CRV4x4
Dec 12, 2013 08:43 AM
