Obd0- obd1 wiring, Extra wires? wtf
Old Jun 20, 2006 | 10:36 AM
yergai's Avatar
Default Obd0- obd1 wiring, Extra wires? wtf
Hey im doing the obd0 to obd1 wiring crap , and i used this diagram.
However What do i do with the left over wires.??
http://www.hasport.com/Tech/Wr...1.htm
How come everything there isn't complete, are the wires not used anymore? Or what's the deal?
For example: OUt of 15 pins on the B plug, i only see 8 on this conversion.
Is this diagram just not correct?
OH and i have two extra wires from the distributor, one is white i believe and the other is blue. Where do those go.
Old Jun 20, 2006 | 10:37 AM
yergai's Avatar
Default Re: Obd0- obd1 wiring, Extra wires? wtf (yergai)
If i don't make any sense, Let me know.
Old Jun 20, 2006 | 10:53 AM
yergai's Avatar
Never mind, I kept searching and solved the distributor problem. I just need help on the rest. Thanks.
Old Jun 20, 2006 | 10:54 AM
court's Avatar
25 Year Member
restate your queery please
Old Jun 20, 2006 | 10:58 AM
yergai's Avatar
Default Re: Obd0- obd1 wiring, Extra wires? wtf (court)
| A1 | BRN | INJ1 | INJ1 | -> A1
| A2 | YEL | INJ4 | INJ4 | -> A7
| A3 | RED | INJ2 | INJ2 | -> A3
| A4 | GRN/YEL | VTS | VTEC solenoid | -> ADD -> vtec selenoid
| A5 | BLU | INJ3 | INJ3 | -> A5
| A6 | ORN/BLK | PO2SHTC | O2 sensor (heating element) | -> ADD [o2 heater control ->blk (under wht wire)]
| A7 | GRN/BLU | FLR1 | fuel pump (main relay) | -> A12
| A9 | BLK/BLU | IACV | IAC valve | -> A11
| A12 | GRN | FANC | engine coolant temp switch | -> B4
| A13 | GRN/ORN | MIL | MIL (check engine light) | -> B6
| A15 | BLK/RED | ACC | (a/c compressor clutch) | -> B3
| A16 | WHT/GRN | ALT C | alternator | -> B5
| A20 | RED | PCS | EVAP purge control solenoid | -> A6
| A21 | YEL/GRN | ICM | ICM | -> B15
| A23 | BLK | PG1 | ground *(main relay ground) | -> A2
| A24 | BLK | PG2 | ground *(main relay ground) | -> A4
| A25 | YEL/BLK | IGP2 | to main relay and to gound for o | -> A13 [splice for o2 -> blk (under grn)]
| A26
What do i do with a19, a18, a17 etc.... Do i just match those up to the Obd0 plug
Modified by yergai at 12:10 PM 6/20/2006
Old Jun 20, 2006 | 10:59 AM
yergai's Avatar
If anyone can help me, My aim is
jonxmar
Old Jun 20, 2006 | 11:11 AM
court's Avatar
25 Year Member
unless you want things like a/c clutch, auto sensor, ect, then you should not worry about it. follow the diagram on the internet. If you have any doubts, go to rywire.com and purchase and buy
Old Jun 20, 2006 | 02:52 PM
mahatma's Avatar
Yeah my conversion harness had mass unused pins....
DEADLYACURACCY
Dec 20, 2006 10:06 AM
WHORE: JDMCoveralls
Jul 8, 2006 07:07 PM
jDMJeRk
Feb 25, 2005 07:44 AM
ZColeon
Jan 23, 2003 12:29 PM
