General TIG welding information.
Old Jun 20, 2006 | 09:24 AM
R@mon's Avatar
Default General TIG welding information.
I see a lot of tips being posted in different threads. I figured it would be good if there was one thread just about TIG welding. Anyone that would like to share information such as:
*Pros and Cons to different tungsten sizes.
*Effects of different cup sizing
*Effects of different torch angles
*Torch angles, filler feed angles and positioning, and joint type in conjunction with eachother
*Flow rates of gas depending on other factors such as material welded, cup sizes, etc.
*Filler rod diameters in conjunction with material type, thickness, joint type, amperage being used.
*Material of filler rod used for different types of metals being welded.
*Pros and Cons to using a gas lense
*Coloring or any other visible effects of a good weld on different metals.
*Experiences and opinions with different brands of torches, tungsten, cups, etc.
Post any useful information. This should be a great thread for those trying to get into TIG welding but don't have time, money, etc, to take a class.
Old Jun 20, 2006 | 09:54 AM
.dave's Avatar
i HAS questions ?
Default Re: General TIG welding information. (R@mon)
http://www.millerwelds.com/education/TIGhandbook/
http://www.millerwelds.com/pdf/gtawbook.pdf
Old Jun 20, 2006 | 10:11 AM
TurboSI56's Avatar
sounds like the start to a good thread, I too would like to know this info.
Old Jun 22, 2006 | 07:02 AM
R@mon's Avatar
Default Re: General TIG welding information. (TurboSI56)
thank you for the links. Ill be doing some reading .
C_H_A_D
Welding / Fabrication
Apr 23, 2006 05:58 AM
weiRtech
Dec 8, 2005 03:13 PM
bluebird
10
Oct 15, 2004 07:28 PM
